red light right side of dash
Old Oct 12, 2018 | 10:24 AM
MattBriz's Avatar
MattBriz
Default red light right side of dash
2016 FatBoy
2cd time its happened.............red light on dash on right side straight across from hi beam indicator. first time it happened harley tech says its got somewthing todo with turn signals? both times its happened have been out on hiway at 60mph or better. downshift to 4th or 3rd and it goes out. owners manual says its for a security system that my bike isn not equipped with. any ideas as to what it actually may be? thanks in advance
Old Oct 12, 2018 | 10:49 AM
Mike Lawless's Avatar
Mike Lawless
Does it look like a key? And have you installed an LED turn signal relay/modulator?
Old Oct 12, 2018 | 06:25 PM
Bwall77's Avatar
Bwall77
Had the same thing on my 2011 that I recently bought. Previous owner installed an LED brake light with integrated signals. That's what was causing mine when the brakes were applied...bike senses it as a lamp out due to lower power pulled by the LED lamps. Have you tried to pull a code from your bike?
Old Oct 14, 2018 | 08:23 AM
MattBriz's Avatar
MattBriz
yeah i converted to LED headlamp and fog lights. turn signals and tail/brake are still stock. someone told me about a resistor to make that light go out if i was really worried about it. havent had time to look around for the resistor or who makes it.
Old Oct 14, 2018 | 09:55 AM
Bwall77's Avatar
Bwall77
I couldnt deal with the light being on. This is what I used:
Dorman 50W6O-AL Aluminum Load Equalizer https://www.amazon.com/dp/B00NF0KIYA/ref=cm_sw_r_cp_api_nH1WBbDQHGW1V
Old Oct 18, 2018 | 06:50 PM
RANGER73's Avatar
RANGER73
I think on the 16's you can reprogram the ECM CANBUS or whatever the hell it's called so it accepts the LED's..
Old Oct 18, 2018 | 08:35 PM
hattitude's Avatar
hattitude
Do your turn signals also hyper flash?
On the CanBus bikes, no equalizer is needed for LEDs... there is a procedure to allow for the ECM to accept the lower voltage of the LEDs...
Maybe do a search, it's been posted on here before...
NOTE: I found two different procedures. Not sure if they are the original procedure I read several years ago.. but can't hurt to try them.
One says to let the 4-way flashers, flash for 30 seconds, and then the hyper flash will stop.
The other says to have the 4-way flashers flash 10 times, shut off the bike. Then turn on the bike and have the 4-ways flash another 10 times.... all normal after that.
705wileyh
Electrical/Lighting/Alarm
Apr 1, 2015 08:11 AM
Matt K
May 26, 2014 07:28 PM
KopeX
Apr 24, 2012 06:32 PM
amorton
Jun 5, 2007 02:19 AM
Cohiba_Joe
Jan 7, 2006 12:35 PM
