i put a BDL on my 94 fxlr, i got a aftermarket 4 speed case and put my 5 speed transmission in it, now it will not shift, i bought another one. same thing, clutch is working just dont shift right,.how do you adjust the bolt on the shifter prawl?
What else did you do?
As the belt has not much to do with shifting unless you scrwed up the clutch adjustment so it will not release...which is my first guess.
When you pull in the Clutch lever, does it release? (as per instructions with BDL )
