LED strip front turn signals
I know there are a few different threads on here, but nothing I can find that really addresses the differences in brightness between LED makes.
I'm looking at all three of the following to stick on my Slim as I'm not a fan of the bullets. I know some are out there that are white run/amber turn, but only looking for ones that are just amber. I know that there are other options, Custom Dynamics, etc... but only looking for this style.
I'm hoping those that have them can tell me how bright the following are, and if you feel less safe after putting them on. The two wire/three wire doesn't matter since of the three of them, Big Al makes a three wire, and I can get an adapter from Badlands that will make the two wire ones work as a run/turn.
Heinz Bike - https://www.harleycustom.com/product...s-895465/34381
Thunder Bike - https://shop.thunderbike.de/en/Thund...h-housing.html
Big Al KG3 - https://www.bigalscycles.com/product...t-turn-signals
Thanks in advance for any advice,
Winston
Those look real similar to the Thunder Bike ones, but about 1/3 the price. With the Badlands adapter they'll work as running and turn, which is what I want, and still a lot cheaper than the Thunders.
Thanks Mike ...
Video:
I know you don't wont the DRL, but you could wire the blinkers only if you like. I like how wide this signal is compared to the others.
https://www.customdynamics.com/dynam...oftail?cat=466
You can also get them in a three wire version with a built in white LED position light.
Thanks again for all the input, if anyone else has any of the ones I mentioned I'd still like to hear thoughts.
Winston
I appreciate all of your responses. I wasn't ignoring you guys, but I've tried twice to do a multi quote back and I get a message that says my post has to be approved by a moderator and for whatever reason it isn't getting posted. I'll try it a different way and hopefully the third time is the charm...
Mike - this is the Badlands intensifier I'm looking at. It will make the two wire turn signals function as running lights.
JW - I like those Leverz, and actually I do want the DRL function, but I don't like that the ones on those are white. I do really like how wide they are though, just wish they were amber for both functions. I know, picky picky, but I like what I like ;-)
Felix - I like how bright they are, but want to stick with amber for both DRL and turn signals. The other issue is that I've got a QR windscreen and don't think they'd work with the spacers that are on the forks.
Thanks again for all of the input, and sorry it took me this long to figure out how to get it posted.
Winston
