Alignment 2011 Heritage Softail
Old Dec 1, 2018 | 12:00 AM
Stuffa's Avatar
Stuffa
Default Alignment 2011 Heritage Softail
just after a bit of advice my 2011 Heritage has always pulled a little to the left if I take my hands of the bars. To get it to run straight I need to shift my body weight over to the right. I’ve checked my wheel rear wheel alignment numerous times and it is right measuring from swing arm bolt to axle. Also belt seems to run true.
Any ideas why the bike doesn’t run straight
Old Dec 1, 2018 | 03:59 AM
Wizardofaus's Avatar
Wizardofaus
Are the fork tubes equal length in the head stock ?.
If the tubes are off set that will cause a mild tack to one side, just something to look at being you say the **** end is running true.
Wiz 🍺
Old Dec 1, 2018 | 08:07 AM
Bluraven's Avatar
Bluraven
First fix; don't take you hands off the bars
My 09 Heritage has always pulled to the left; I believe it's the nature of the bike.
When I put my tool roll and rain gear in the right saddlebag it did seem to offset the drift a bit so perhaps that might work for you if the drift is an issue.
Old Dec 1, 2018 | 08:35 AM
golfblues's Avatar
golfblues
My 09 Heritage always pulls to the left. If I take my hands off the bars I have to shift my butt over to the right about 3 in. And everything is in alignment.
Old Dec 1, 2018 | 07:26 PM
jkinner's Avatar
jkinner
Same on my 16 Deluxe, +1 with Bluraven, I don't take my hands off the bars. Ride safe, Merry Christmas.
Old Dec 1, 2018 | 08:02 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I spent a lot of time on the same issue on my 2012 Heritage. It can take a bit to make sure everything is aligned correctly, and even then it can pull a bit one way or another. Sometimes this is due to it being solid mounted and HD tolerances are a bit loose, resulting in the engine being mounted, ever so slightly, off-kilter.
Once you get everything aligned, including the forks, perfectly, if it still pulls, then adjust the alignment a bit to get it to go straight. You may end up with slightly more wear on one side of the tire, but at least you will have a bike that goes straight down the road.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Dec 2, 2018 | 08:26 AM
swifty's Avatar
swifty
My bike pulls to the left also. One day I put it in neutral while going down a hill, took my hands off the bars and the bike ran straight! It must have something to do with the left side drive.
Shazam7561
Feb 3, 2016 07:11 AM
arrowslinger1980
Apr 29, 2014 09:07 AM
arrowslinger1980
Jul 3, 2012 02:31 PM
Robcat
Jul 24, 2010 04:50 PM
paud
Jun 26, 2010 04:11 PM
