Burnt Nose Cone Wires
Old Mar 9, 2019 | 05:28 PM
zivkos's Avatar
zivkos
Stage III
Default Burnt Nose Cone Wires
This question is regarding a 98 FLSTS.
While dissembling the cross over pipe the timing/nose cone wire was pinched between the center post and the cross over pipe. This is the wire that runs from the nose cone up to underneath the on/off switch between the tanks. Appears to have been made that way. Two of the wires were burned through the insulation to the bear wire. Don't no why it still ran.
There are 5 wires (black, red,white,brown, green). A 2 inch splice is going to be needed. So what code and gauge wire is this?
The dealer would not say what wire it was and neither would Milwaukee claiming liability.
It would be greatly appreciated to find out what wire this is.
Thank you
Old Mar 9, 2019 | 05:31 PM
Juan L's Avatar
Juan L
Moderator
Can you take a picture of the wire?
Old Mar 9, 2019 | 05:36 PM
zivkos's Avatar
zivkos
Stage III
An attempt will be made. are computer equipment is as old as bike.
Old Mar 13, 2019 | 07:46 AM
Mattbastard's Avatar
Mattbastard
Yea man, I pic is worth a thousand words. Or find it on the Ronnie's Microfiche and show us that way.
More than likely it's just 16ga stranded copper conductor. I'd advise against using a solder joint. The heat from the solder joint makes the copper wire brittle, then over time from vibrations it will crack and fail. Use a compression splice.
Old Mar 24, 2019 | 09:45 AM
Juan L's Avatar
Juan L
Moderator
I guess the OP couldn’t master the technology of posting a picture and I now have serious doubts about his ability to fix a wire.
Bill wallace
Shovelhead
27
Feb 16, 2021 08:00 AM
zivkos
2018+ Softail Models
Mar 10, 2019 09:29 AM
Rusty Axle
Shovelhead
Jan 20, 2019 05:20 PM
bobbyjoes
2014-2024 Touring Models
May 5, 2017 08:42 PM
Danielc409
Jul 8, 2013 01:16 PM
