2003 softail springer primary oil level
I did find a owners manual online and while it had the engine and transmission oil change procedure it didn't have any real info on primary. Interesting enough I checked my 03 touring owners manual and it has the procedure for all three. Any help would be appreciated as I'd like to do it Monday morning.
To answer your question, both my '01 HD Softail Service Manual and my '03 HD Softail Service Manual say approximately 26oz... and then show a pic, like the one posted below, for the proper level...
I wouldn't get too hung up on the amount listed in the service manual.... that is usually a good guesstimate... but whether it's a wet fill, or dry fill and the size of your primary cover (they changed over the years) will dictate the amount they suggest.....
Whether it's a softail, touring, dyna, or even an M8...... they may have different amounts, but they are all trying to get the primary oil level to the same place...
Bottom line, if you fill to the bottom of the clutch basket, with the bike level, you will be where you need to be....
PS- It will be anywhere between 26 oz and 36oz depending on wet fill/ dry fill/ narrow primary/ normal primary/ year of the bike etc.... I start at around 25oz and then top off to the bottom of the clutch basket by eye......
