Harley Hard bag conversion kits on Amazon? Good or no?
There are not OEM quality but aren't that bad and have been pleased with them.
Another decision you'll need to make is what type of mounts do you want.
You can go with the cheapest:
You can go with the more expensive and most supportive:
I went in between and got the "Asian" baggertail knock-offs off e-bay for $105.
I looked on ebay but don't see what I got listed so perhaps they aren't made anymore.
In any case; knowing what I do I would pay up for the Baggertail or similar mounts due to they are very supportive.
I can load either bag down with a lot of weight and the bags stay firmly in place without sag or flexing.
But with a little English it fit.
I tried contacting them about the issue I was having and about 1.5 weeks after I adjusted the kit so it would fit I got a response.
They were kind of in a huff over my review of there product.
I told them if you advertise customer support you should actually give it.
Also the kits I have seen most (not sure all) say you can use the stock passenger peg bolts.
DON'T. Go to your local hardware store (or order some online) (unless the kit comes with them) and get the next longer bolt & use some blue loctite when you install them.
The bags work fine, decent quality (not HD fit/finish).
I will be swapping over to Rushmore bags (finally) in the next week or so (parts still coming in).
The bags need to be supported at the bottom like the factory
set up. it is more $, but by far a better set up.
I would put some kind of insulation on the support rail.
That would also raise the bags up a hair, then adj those little
swivel mounting brkts accordingly.
That puts the bottom of the bag even with the bottom of the fender.
sorry they came out sideways, not sure how to fix that.
I bought lowers and extended bags for my RG custom from Mutazu and they were very good quality and good service. You can get them in primed, vivid black or matte black.
here is a link for Vivid Black with all the mounting hardware for < $300
https://www.mutazu.com/products/harl...for-harley-h-d
If you want extended bags they also offer those. But on a fatboy-Deluxe or Heritage extended are easy to drag and IMO dont look as good matching up with the stock rear fender
I've been running Road King bags with Baggertail brackets on my Deluxe and decided I want something I could lock up. Found a like new set of 2012 Street Glide bags in Demim black on CL. Had to extend the u-shaped brackets but it worked. Once I got them on I didn't like the way it looked. I've got my thoughts as to why but wonder what you all think.
How did you get your passenger footboards to fit? I just finished installing bags and trunk purchased from NastyHog.com, and I can't mount my passenger footboards.
