Slim S Pull Back Riser Kit
Old Mar 27, 2019 | 02:26 PM
GKstreetglide's Avatar
GKstreetglide
Default Slim S Pull Back Riser Kit
Anyone install the Softail Slim Pull Back Riser Kit, Part Number: 55900165 on an ABS Bike? The listing says a brake line kit is required for bikes with ABS and I'm curious if anyone that installed these actually changed the brake line or will the kit work without this change? My wife wants to add this to her 2016 with ABS and if I have to change the brake line we may look for different options.
Old Mar 27, 2019 | 05:21 PM
MNtadpole's Avatar
MNtadpole
I had the shop do it, and they required a longer brake line. I can't say that I ended up really caring for the look of the pull-back riser. I think it looks like a chromed out mac noodle.
Old Mar 27, 2019 | 06:56 PM
pigfoot63's Avatar
pigfoot63
I have these on my 2018 Heritage with ABS and yes I had to change front brake line, also had the same risers on 2017 Slim both clutch line and brake line worked but brake line was a tight fit so I changed it out.
Old Mar 29, 2019 | 05:33 AM
ratsnest's Avatar
ratsnest
we put risers from a Deluxe on ... way cheaper and do the job well
Old Apr 15, 2019 | 10:27 AM
GKstreetglide
Ratsnet, which Deluxe Risers did you install on a Slim? Do you have the part number and did this require a brake line change?
Old Apr 17, 2019 | 12:33 AM
sjnjr's Avatar
sjnjr
I'm curious as well
rquest
Dec 4, 2020 11:43 PM
pigfoot63
Mar 26, 2017 10:41 AM
semifan1
Mar 7, 2014 11:23 PM
HDJIM1158
Feb 5, 2013 02:57 AM
Talldog
Oct 21, 2010 06:58 PM
