turn signal problem
Old Apr 21, 2019 | 09:37 PM
frozeneyeball's Avatar
frozeneyeball
Default turn signal problem
1999 fatboy, today I noticed that my right front signal stays on but don't blink and my rear right is a led and it does not light up at all. left ones work fine, could rear led be out making it do this ? any ideas cause im not real electricalk smart.
Old Apr 24, 2019 | 09:27 AM
hattitude's Avatar
hattitude
Do you have LEDs on all four signals or just the rear? Do you have a signal stabilizer in the circuit? Do you have a run/stop/turn module in the rear light circuit?
Quick test, switch the rear turn signal bulbs.... if the problem changes sides with the bulb switch, then the problem is that rear bulb...
If it doesn't switch with the bulb, and you have the signal stabilizer or run/stop/turn module, I would then suspect one of them. Take them, one at a time, out of the circuit and see if it goes back to normal operation.... if you remove one of those items from the circuit, and everything works properly, then the item you removed is bad and needs replacing..
Note: the turn signals will hyper flash when you remove the signal stabilizer, but that's normal for LED turn signals without the stabilizer...
cijs88
Jun 5, 2025 05:21 PM
CJinNH
Aug 11, 2014 09:26 AM
Paulbpilot
Jun 30, 2012 06:12 PM
04nightrain
Electrical/Lighting/Alarm
Apr 4, 2011 11:15 PM
fiscomi
Jul 30, 2010 09:03 AM
