Difference between 1999 and 2000 Fatboy Wheels
Old Oct 26, 2005 | 07:13 PM
jhogan20's Avatar
jhogan20
Default Difference between 1999 and 2000 Fatboy Wheels
I wanted to buy a set of Fatboy wheels on ebay but they were for a 00 and newer. What would I have to run them on my 97 Fatboy?
Old Oct 26, 2005 | 09:15 PM
pococj's Avatar
pococj
Default RE: Difference between 1999 and 2000 Fatboy Wheels
IIRC, the axles & bearings are different. Larger axles? on the newer means the axle wouldn't fit your forks. Might be possible to get bearings with smaller inner races to fit your axle.
Old Oct 26, 2005 | 11:19 PM
fatty47's Avatar
fatty47
i have a 1999 fatty and still have the stock disc rims with tires sittiing in my basement....where are you located?
let me know if your interested..i can take pics...tires are decent...but rims look great they are brushed NOT chromed..
[IMG]local://upfiles/4577/598A3F9EFAC94F5B82991A617837BE5D.jpg[/IMG]
Old Oct 27, 2005 | 07:29 PM
jhogan20's Avatar
jhogan20
Thanks!
Old Oct 28, 2005 | 12:16 PM
SHEP's Avatar
SHEP
WRONG!
The axles are the same on both the 1999 & 2000. The difference is in the bearings and the raised rotor center. The 2000 rotors have a larger center hole. Because of the sealed bearings the 2000 wheels use a different length spacer. The 1999 and down wheels have bearings, seals and outside washer.
You can put a 1999 wheel on a 2000 model by using the earlier spacers and the 2000 rotor. However, in order to put a 1999 wheel on the 2000 model you would have to make the center hole on the rotor larger and use different spacers. You will also have to modify the rear pulley to fit on the later wheel.
Bottom line is that is is easier to find a set of correct year wheels on ebay.
Old Oct 28, 2005 | 12:46 PM
jhogan20's Avatar
jhogan20
Thanks, good info!
Thanks for the offer on the wheels Fatty47 but I'm looking for poshised or chrome ones.
Old Oct 28, 2005 | 02:01 PM
Babs's Avatar
Babs
This brings an interesting subject.
Also I think there is a difference in the 03 and later rear tires verses earlier 00 and later?
Reason I ask is you see a lot of chrome exchange fatty wheels out there and I'm not even so sure they know there's a difference.
Ah if I just had a parts manual infront of me, I could just look 'er up.
Old Oct 28, 2005 | 04:20 PM
mutha's Avatar
mutha
jhogan
they sell chrome wheel covers for the older models that look sweet, and you would never know also it covers the holes around the wheel so the y are easy to clean
Old Oct 28, 2005 | 04:27 PM
mutha's Avatar
mutha
here is a pic they are on ebay item numbers:4585686177 & 4585447769
let me know
[IMG]local://upfiles/2551/E46D0E8504CB43FEAB8223C549235A50.jpg[/IMG]
Old Mar 31, 2015 | 01:43 AM
trilby1's Avatar
trilby1
Stage III
can any body tell me the different between a 2000 fat boy and a1999 fatboy.ive got a 2000 soft tail standard and I want to put fatboy fork tins on the front are the fork tins a different size . ive put fat boy yokes on the bike wich fit ok.
Tharry91
May 14, 2017 02:10 PM
Rewind
Wheels/Tires
Jul 24, 2009 01:14 PM
zell90r94
Apr 17, 2009 07:47 AM
morrisr2000
Jul 12, 2006 03:04 PM
newdm04
Mar 12, 2006 03:26 PM
