Mainshaft inner race too far on
Old May 21, 2019 | 07:19 AM
Michael San Filippo's Avatar
Michael San Filippo
6th Gear
Default Mainshaft inner race too far on
So I took my bike in, from the pictures the mechanic sent me it looks like he put the race on the inner primary flush against the seal instead of leaving the 1/10 or whatever it is he’s supposed to in order to pull it off in the future.
Is that hat going to cause rubbing or just a pain in the *** to pull off next time I need to replace it?
Old May 21, 2019 | 07:22 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Model and year......
Old May 21, 2019 | 07:24 AM
Michael San Filippo
6th Gear
1991 Heritage Softail Classic
Old May 21, 2019 | 09:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Did you ask the guy that installed the race about this?
If you paid to have it installed, you should not accept it unless done properly.
Old May 21, 2019 | 10:12 AM
Michael San Filippo
6th Gear
Was a buddy of mine.
Im not concerned as long as it’s not gonna cause a problem.
If its it’s just gonna make it a PITA to change it in the future that doesn’t bother me.
Old Jun 3, 2019 | 05:51 AM
Robb Liupo's Avatar
Robb Liupo
You may want to have him re-do it. It's not uncommon for the races to walk on the shaft. If they walk toward the transmission it will take out the seal and be very difficult to remove. There is a special tool you can get that will help remove a race that has walked all the way to the trans seal. To use it you cut a groove in the race then the took grips that groove and pulls it out. Good luck. In my limited experance, the races are a bitch to remove and to reinstall. Doable with the right tools but not an easy job. The spec for my bike was .100 to .125 gap. I could not install the race any farther than about.130
miketv84
Jun 5, 2019 05:04 PM
Jake76
11
Aug 15, 2012 09:30 PM
Panshovevo
EVO
Nov 11, 2011 09:26 AM
PotterBoy
Sep 7, 2011 09:55 PM
z28scotty
Aug 16, 2008 07:52 AM
