Battery voltage drop
Old Nov 13, 2019 | 12:34 PM
rtstevens's Avatar
rtstevens
Stage II
Default Battery voltage drop
I have a 2008 sportster XL1200 low. Battery voltage drops from 13v to 5v when I plug in the 30amp main fuse. Tried unplugging several things, still have the problem. Any thoughts?
Old Nov 13, 2019 | 01:27 PM
mmesa005's Avatar
mmesa005
I would first check the battery and starter solenoid cables to make certain they are not damaged or grounding. Then I would test for "Shorts to Ground" http://www.cycleelectricinc.com/
Old Nov 13, 2019 | 01:42 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Why are you doing this, are you having an issue?
Old Nov 13, 2019 | 02:39 PM
rtstevens's Avatar
rtstevens
Stage II
I had my bike on a trickle charger for a few months and when I came home and tried to start it all the lights went out and nothing would work, that’s when I started checking the electrical and discovered the voltage drop.
Old Nov 13, 2019 | 08:15 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Forget the voltage drop for the time being, you have a dead battery.
First you need to charge the battery fully and have it load tested (it sounds like it is kaput).
While the battery is out, clean all the battery cable connections.
Old Nov 13, 2019 | 08:18 PM
TriGeezer's Avatar
TriGeezer
Have the battery load tested. A battery can read at spec with no load, then as soon as even a minor load is put on it, the voltage drops.
Old Nov 17, 2019 | 09:01 AM
hdbob2006's Avatar
hdbob2006
If you had the battery on a trickle charger [not a battery tender] for a few months,you have ruined your battery.
Old Nov 19, 2019 | 01:58 PM
ghost183's Avatar
ghost183
x2!!!!
common mistake trickle vs tender
BiggCliff412
Electrical/Lighting/Alarm
Oct 22, 2019 06:47 AM
voudoujoe
15
Aug 24, 2016 03:07 PM
Fatair96
13
May 18, 2016 12:24 PM
KW HD
Jun 15, 2015 04:30 PM
thebamaguy
EVO
May 18, 2011 03:21 PM
