14 Softail Slim fork diameter
Old Dec 30, 2019 | 02:03 PM
brucepancake's Avatar
brucepancake
Default 14 Softail Slim fork diameter
Hello, I am thinking about putting the TrueWrapz wrap-around turn signals on the bike I called Harley and they said they were 39 mm. I cant believe that. That is the smallest size revzilla has in these turn signals and my forks look huge towards the top
Thanks for your help guys. And I was going to change the headlight bulb to an LED. any cheap suggestions. I want a white light look in the front. Not the yellowish tint.
Old Dec 30, 2019 | 02:27 PM
WKNDS's Avatar
WKNDS
...snip....
The actual fork tube size is 41mm, but on Slims there's the "cowbells" that cover
the fork tubes from the lower tree down to the sliders (unless you have removed them).
There's also the upper front/rear facia behind the headlight that cover the fork tubes & trees
(again unless you've removed them).
good luck,
T.
Old Dec 30, 2019 | 02:30 PM
WKNDS's Avatar
WKNDS
If you want to put these wrap-arounds on the cowbells, just get a length of string, wrap it
around the cowbell, mark it & measure it / divide by 3.17. Pretty easy to do...
From the Custom Dynamics website; see "How to Measure"
https://www.customdynamics.com/amber...truwrapz?cat=2
hth,
T.
Old Dec 30, 2019 | 06:36 PM
brucepancake
I am going to put them on the forks right below the black plate. In this picture, there is a silver screw in the picture where my current turn signals are located. It is 10 inches in diameter at that spot. What size of wrapz would you all recommend?
I dont think I will need to remove any parts. Hey and thank you
Old Dec 30, 2019 | 08:44 PM
WKNDS's Avatar
WKNDS
What you have indicated are the "cowbells", NOT the actual fork tubes. I would recommend
going to the Custom Dynamics website and utilize their 800 phone number to talk to them
directly for their recommendation. Ok, its 800-382-1388
good luck,
T.
Old Dec 31, 2019 | 10:30 AM
brucepancake
I did and they were unsure and I called Harley and they told me it was 39 mm but that size is too small. Thank you for your help T. Is it ok to put them on the cowbells? Are those covers for the forks?
Old Dec 31, 2019 | 10:44 AM
WKNDS's Avatar
WKNDS
Yes, as I mentioned a few posts back, they are covers for the actual fork tubes.
Its YOUR bike, you can put them where you want. Again, its easiest to just get
a small string, wrap it around the cowbell, measure it, then divide by 3.17 to
obtain the diameter....
Here's the microfiche from RonniesHD showing the parts diagram (the cover is #27)...
http://partsfinder.onlinemicrofiche....ORK%20ASSEMBLY
good luck,
T.
Old Dec 31, 2019 | 11:07 AM
brucepancake
So 56 mm wrap arounds are the biggest and will cover 7 inches of circumference around the cowbell. I think I can make it work. There has to be three inches behind that I can hide. And the location helps as well. Right under the black plate that holds the headlight. And wo you have any suggestions for an LED headlight replacement bulb. Would this work
https://www.revzilla.com/motorcycle/...headlight-bulb
Old Jan 2, 2020 | 01:26 PM
brucepancake
Has anyone used these? I love this look and the lights are in a metal housing
​​​​​​https://www.customdynamics.com/dynam...oftail?cat=475
ss27gogeta
May 1, 2018 06:29 AM
Oakleyrider
Shovelhead
Jun 27, 2017 12:21 PM
Woodys03
May 16, 2014 02:04 PM
parts eeter
Sportster Parts
May 29, 2013 03:25 PM
klug99
Dec 2, 2011 03:52 PM
