stupid gas question
Old Jul 19, 2007 | 05:16 PM
heyrob's Avatar
heyrob
Default RE: stupid gas question
Make sure you clean your tank real well when you spill gas. Use a quick detailer or at least water and a clean rag (not a gas station paper towel -- may as well use sandpaper). Gas will eat away your wax and if left on there, will gradually etch and discolor your clearcoat.
Old Jul 19, 2007 | 07:55 PM
jeffflsti's Avatar
jeffflsti
In your case it will take practice. grab one of them paper towels before pumping if it has to be.
Old Jul 19, 2007 | 08:19 PM
eravo's Avatar
eravo
I do the same as bgismo20...
Old Jul 19, 2007 | 09:55 PM
shengte's Avatar
shengte
6th Gear
You guys are awesome, thanks for all the quick responses. I will def have to try them out.....
Old Jul 20, 2007 | 08:54 AM
purple haze's Avatar
purple haze
DO as TUNAMAN says just hold nozzle and slowly add the gas also it is handy to have a couple of DAMP paper towels in case of a tank wipe off. PURPLE HAZE.
[IMG]local://upfiles/24725/9D9150D2EA2E41E39021BC7C8B0749A6.jpg[/IMG]
Old Jul 20, 2007 | 04:08 PM
shineybike's Avatar
shineybike
I tried setting the automatic fill gizmo on the nozzle once at a Cumberland Farms station. It didn't turn off and gas poured all over the HOT engine. I almost crapped myself thinking it was going to burn up the bike. Needless to say I will never do that again. I fill slowly and watch the level in the tank as I go. Can be tough if it's sunny or you have your sunglasses on.
Old Jul 20, 2007 | 04:55 PM
Oldtimer of NM's Avatar
Oldtimer of NM
This is caused by the backwash when the end of the nozzle is blocked by gas and trips the auto shutoff. Best to put the end just far enough into the tank to keep the gas going the right direction and manually shut it off before the gas reaches the ring inside the filler. If you need to fill the tank as much as possible, top it off by tapping the lever.
Old Jul 20, 2007 | 07:39 PM
shengte's Avatar
shengte
6th Gear
heyrob,
what do I do if it does eat away the clear coat??? I spilled some gas on the tank and didn't clean it for a few days.....help!!!
Old Jul 20, 2007 | 08:46 PM
purple haze
WASH tank with soap and water and lay some good Carnuba Wax on tankand wipe off, it should help better than not having any thing on paint. GOOD LUCK! PURPLE HAZE.
[IMG]local://upfiles/24725/883EE3DC94DC4BE1A676DED34C6062CD.jpg[/IMG]
Old Jul 20, 2007 | 08:55 PM
jharp's Avatar
jharp
I'm real carefull, I don't have wax or clearcoat. I hold the big rubber boot with my left hand and go as slow as it will let me.
Jim
A#1
Apr 15, 2019 03:04 PM
babaharley
Oct 3, 2017 08:54 AM
Geezr Glidr
Mar 2, 2012 09:42 AM
Old Bones
May 19, 2011 07:53 PM
MountainCat
Jul 15, 2007 11:36 PM
