Do I need remap or something like V&H FP3?
Old Mar 12, 2020 | 05:05 PM
Shacky73's Avatar
Shacky73
Default Do I need remap or something like V&H FP3?
Putting slip ons and K&N air filter (stock intake).
Will reflash be necessary?
Old Mar 12, 2020 | 05:43 PM
MyFavRk's Avatar
MyFavRk
You'd be doing your self a favor by having a tuner installed . Changing the stock pipes will probably reveal more popping on decel than the stock ones , especially if you change the filter as well . The bike is already running lean , adding those will make it even more . Going with a Power Vision or FP3 would be a good idea , and if you ever decide to go with a set of cams , you can easily dial it in without having to spend more $$$ to get it done .
Old Mar 13, 2020 | 06:35 AM
jkinner's Avatar
jkinner
I did the same add ons to my 16 Deluxe, I went with the FP-3 works great, bike runs a little cooler no surging at low cruise speeds, 99% less decel pops. Good luck with whatever you decide, Ride Safe.
Old Mar 13, 2020 | 07:02 AM
Big Mule's Avatar
Big Mule
What year is your bike? If it’s a new model, then you may want to let the dealer do the flash/tune because of the warranty.
Old Mar 13, 2020 | 09:00 AM
Shacky73's Avatar
Shacky73
2017 Heritage 103. Off Warranty
i see basic PV is same $399 from Moto Fuel without autotune.
Old Mar 13, 2020 | 09:43 AM
CaptainKirk's Avatar
CaptainKirk
We can talk about an FP3 on Sunday! I have one and it's the easiest DIY tool out there!
Old Mar 13, 2020 | 10:02 AM
MyFavRk's Avatar
MyFavRk
Using the FP3 as well , love it and the customer service is outstanding .
Old Mar 13, 2020 | 11:25 AM
koolbreez's Avatar
koolbreez
if you do both yes get a tuner I installed TTS mastertune it just flashes ecm saves original tune gives you a lot of options
Old Mar 13, 2020 | 03:43 PM
Fat11Lo's Avatar
Fat11Lo
Best bet^^^^^^^^
Free base map from Fuel Moto and you can dial it in with autotune basic feature.
Old Mar 15, 2020 | 03:37 PM
Valdemar's Avatar
Valdemar
If you can go to profesional with dyno tuner, do the modification in the dyno. is better than Power vision or FP3.
