Primary whirling noise
Old Apr 1, 2020 | 06:58 AM
Brunske15's Avatar
Brunske15
Stage II
Default Primary whirling noise
2015 HD Fatboy with 3800 miles on it. I recently got this fatboy and the first thing I did was a 3 hole fluid change with the Maxima Synthetic oil change kit.
I cant be certain if the noise was present before because I only got to ride the bike one time before the fluid change.
Get down on the ground near the bike while it is running the noise is coming from the primary towards the rear of the bike. (bike is in neutral, does not stop with clutch pulled)
I haven't re-checked the fluid level of the primary yet but I did put around 28-30 ounces of primary fluid in when I did the service.
I've read on this forum of members with similar issues but they have around 20-30k miles on their bikes.
Is this a 'normal' noise then or do I have an early failure of a bearing or other part?
Old Apr 2, 2020 | 07:01 PM
donhoe's Avatar
donhoe
I have the whirling noise on my 2017 FLSS as well. Took it to the dealer, they said it's normal? (30000 kilometers)
Old Apr 3, 2020 | 07:11 AM
jkinner's Avatar
jkinner
Its probably the balancer you hear, https://partsfinder.onlinemicrofiche...AFT%20ASSEMBLY This is what I think you are hearing. Ride safe
Old Apr 4, 2020 | 08:51 PM
Brunske15's Avatar
Brunske15
Stage II
After riding today I discovered that the noise is only prominent after the bike warms up
Old Apr 4, 2020 | 09:40 PM
Screamin beagle's Avatar
Screamin beagle
could be the primary chain tensioner. I had the stock auto adjuster then went to the hayden about 2 years ago, both of these were quiet. I replaced the hayden because the shoe was coming apart. I went with the screaming eagle manual tensioner...its quiet until it gets warmed up then it's a box of marbles at idle and off throttle. Im researching putting in something else...soon. Take the cover off and have a look.
Old Apr 5, 2020 | 07:16 AM
y22c's Avatar
y22c
My 2012 FLHX has been whirring for the past 35K miles. I keep looking for anything on the drain bolt magnet, find nothing.
I keep riding with the noise, seems to only bother me.
Ken
Old Apr 5, 2020 | 09:30 AM
jkinner's Avatar
jkinner
My 16 Deluxe has made that noise since new, On my last oil change I went to HD Heavy synthetic gear oil, SAE 80-140 (at my dealers suggestion, @ 20k, 24k now) It is a lot quieter since, shifts a little smother too.
FWIW. Good luck, Ride safe.
lopoko9724
2014-2024 Touring Models
Apr 25, 2018 10:25 PM
UltraClassicElectraGlide
Mar 15, 2015 06:17 PM
StreetGlider56
Nov 19, 2009 10:04 PM
2008FLHP
Jun 19, 2008 07:34 PM
rykegs
Aug 29, 2005 06:19 PM
