Grease under front steering?
Old Jul 23, 2007 | 12:31 PM
clueless's Avatar
clueless
Default Grease under front steering?
is anyone else noticing a lot of grease coming out from the bottom half of the front streering collumn? it oozed out all over the front area of the gas tank and top part of the frame where it goes into the steering collumn area.
is this normal for Harleys? do I need to add more greese or is it just oozing out the extra in the hot weather?
I wiped it up and it seems to have stopped oozing.
Old Jul 23, 2007 | 01:16 PM
RandyM1911's Avatar
RandyM1911
Default RE: Grease under front steering?
The only time I noticed it was after the dealer did the 1000 mile service. He must have pumped a little extra grease into the steering head bearings and it oozed all over the front cylinder head. The service manual says to lube the sttering head bearings every 10,000 miles and disassemble and inspect at 30,000 miles. I wouldn't worry about a little seeping unless you have a lot of miles on the bike. I would just clean it up and ride on.
Old Jul 23, 2007 | 02:11 PM
commander112's Avatar
commander112
Normal. Just clean it up when you see it. It is part of the service process to grease up the steering head.
Mark
Old Jul 23, 2007 | 05:06 PM
Unibomber's Avatar
Unibomber
Yes, normal. The manual actually states to pump grease into zirt until it ooozes outta the neck. So just whip'er off and feel good knowing your steering bearing is good and greased.
Old Jul 23, 2007 | 09:08 PM
YTHOG's Avatar
YTHOG
Mine does it also. Mostly when it's hot outside or in the garage where It's kept. I just take a paper towel and wipe the grease off before and after I ride. Sometimes it splatters on the cylinder heads. It is normal.
Old Jul 23, 2007 | 10:18 PM
Aces N Eights
Guest
Posts: n/a
I have had the same thing. Normal or not it sucks. Especially when you are riding for several hundred miles and someone asks "whats leaking all over your tank?" I try to keep it wiped down but on occassions, it comes back especially after service.
07HC
Old Jul 23, 2007 | 10:50 PM
detonator's Avatar
detonator
Mine does the same, Iwipe it offevery time I clean my bike.
Old Jul 24, 2007 | 03:52 AM
LarryJ00's Avatar
LarryJ00
Mine does it too and it is normal because there is no seal to prevent it. I am curious if it just the Custom's or if all Harley's do this.
Old Jul 24, 2007 | 08:13 AM
larry5h's Avatar
larry5h
Normal.
Old Jul 24, 2007 | 08:25 AM
clueless's Avatar
clueless
thanks all... I guess since the new harley's dont mark their spot anymore ... they have to ooze some fluid still.
yepp this is after the 1000 mile service ... after it got hot the grease oozed all over the behind the steering collumn. oh well, just a check item after tanking up gas each time. I use the wipes at the gas station for cleaning windshields
