Spark plugs
Old Jul 25, 2020 | 03:39 AM
Carl Rumble's Avatar
Carl Rumble
Stage I
Default Spark plugs
What seems to be the preference to brand and type of plugs used in fatboy ?
Old Jul 25, 2020 | 07:05 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OEM plugs.
Old Jul 25, 2020 | 09:52 AM
60Gunner's Avatar
60Gunner
NGK DCPR7E or DCPR7EIX if you want iridiums. These are probably used far more than the OEM plugs which are just Champions sold as HDs probably to command a higher price like their citgo oil.4
Personally I wouldn't run champions in my lawn mower. Or citgo oil for that matter.
But like oil, fork oil, and a host of other stuff, they farm it out, often to the lowest bidder. So if you think you're buying some special Harley Davidson spark plugs or Harley Davidson oil...
Old Jul 25, 2020 | 11:11 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Despite what this rant says, OEM plugs are most likely the most commonly used plugs, on any model Harley...
In 50 years as a mechanic, I have never had an issue with a Champion plug, on anything..
Old Jul 25, 2020 | 11:12 AM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard!
stock plugs are just fine!
Old Jul 25, 2020 | 11:22 AM
hattitude's Avatar
hattitude
The main thing with plugs is to stay within the appropriate heat range for your engine build.... In most HD bikes, OEM plugs are just fine...
All the fancy plugs (iridium, platinum, etc) are great for the extended life of a plug, but Harley plugs are just not that hard to change... And the "snake oil" styles of plugs don't make a difference in Harley engines..
Certain plugs don't play well with the ion-sensing (knock detection) of the Twin Cam engines.... Seems silly to possibly disable the knock/detonation safety system...
You can get a pair of HD 6R12 Plugs for under $10, a pair of the same plugs by Champion, RA8HC, for $5.....
So I stick with the Champion or OEM .....
They're cheap enough and easy to replace so I just replace them regularly.....
IMHO, especially in HD applications, many people tend to overthink the spark plugs....
Old Jul 26, 2020 | 03:35 PM
470004's Avatar
470004
OEM plugs are always in stock at the dealer. No reason to hunt around for the aftermarket plugs.
Cowboy Alex
Jul 19, 2012 10:55 PM
Kojax
Aug 1, 2011 02:34 PM
Darkhorse1
Aug 2, 2007 02:28 PM
Canuck HD
Exhaust System Topics
Apr 11, 2007 06:36 PM
carlosjc401
General Topics/Tech Tips
11
Sep 28, 2006 11:11 PM
