Battery & Warning lights on
So first pulled some codes:
P55P6 - P0562 P0563 END CLEAR
Pn 34454-07E
P55P6 - 60563 END CLEAR (b0563?)
Pn 68925-07
P55P6 - 61006 61007 END CLEAR
Pn 70900069A
P55P6 - NO RSP
This is what I came up with, though I have no experience with them:
ABS
P0562 - Battery Voltage Low
P0563 - Battery Voltage High
Battery, Ignition, Lighting, Accessories
b0563 - Battery Voltage High TSM/TSSM
b1006 - Accessory Line Overvoltage
b1007 - Ignition Line Overvoltage Instruments
After reading this forum posting https://www.hdforums.com/forum/softa...e-running.html
Watching this:
https://www.lawabidingbiker.com/134/
So I believe the minimum voltage on starting tells me the battery is okay. It should be it's only a year old.
Max voltage here tells me there is no charging.
Minimum voltage starting
Maximum voltage after starting, no charging
three pin to pin tests all about 1.1-1.2 ohms.
Low resistence at plug through stator coils, and each pin to engine ground(confirmed working) were all dead shorts.
It looks like the process of elimination says likely the rectifier in the voltage regulator, or the whole thing considering the error codes pulled.
Any other ideas? My dealer is closed Mondays now so I have a day to think on this. TIA
And if it makes a difference now, I always keep it on a trickle charger these days parked overnight.
