2009 softail problem.
Old Oct 9, 2020 | 03:34 PM
musicnbikes's Avatar
musicnbikes
Default 2009 softail problem.
I have a 2009 crossbones, and the battery went dead. I installed a new battery, when I turn it on, the fuel
pump doesn’t activate and when I turn it over it just makes a clicking sound.
many ideas? Thanks!
Old Oct 9, 2020 | 04:51 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I'd try and reset the ECM but have to wonder what killed the baattery,
Old Oct 10, 2020 | 07:34 AM
musicnbikes
I had it on a trickle charger. The power went out, and unbeknownst to me, (we recently moved) the outlet had a fuse in it. It popped, and as such, the battery died. I had shoulder surgery last year, and just now I’m able to ride again. I was home from work for a couple days, and thought I’d get the bike out to ride. I’m going back to work, so I’ll be gone for a while. I’ll have to Try to tackle it when I return.
Old Oct 10, 2020 | 08:34 AM
Bone Doc's Avatar
Bone Doc
It sounds like the new battery is dead (yes it is possible). Do the lights come on when you turn on the ignition? Did you charge the new battery before installing it? A trickle charger or battery tender will not charge a dead or near dead battery.
What is the new battery's current voltage?
Old Oct 10, 2020 | 09:22 AM
musicnbikes
I bought the battery at a Harley deslership. The guy told me it was charged and ready to go.
the lights come on when u turn the ignition switch. The fuel pump is not running when I push the run switch, then when I turn it over it clicks.
Old Oct 10, 2020 | 09:32 AM
Torky_SOB's Avatar
Torky_SOB
Check your fuses possibly the surge may have shorted the fuse that runs the fuel pump
Tonyoz
VRSC Models
Apr 22, 2020 04:42 AM
ibziggy
Jul 27, 2012 05:56 PM
ibziggy
Jul 27, 2012 05:55 PM
Tony I'Anson
Electrical/Lighting/Alarm
Jun 28, 2012 04:30 PM
dwebber
Sep 20, 2009 07:24 AM
