Clearing ECM codes
Any help would be sweet. Everything I have been able to find is on newer models and CVO's
Old codes, new codes, correct them and move on.
Clear them, see which ones come back up and deal with those.
A historical code, is a code from a problem(s) that caused the ECM to set a code(s), but then the issue(s) cleared itself...
After a certain number of engine cycles, if the codes don't pop up again, the ECM will drop them from memory, and it will be back to normal operation...
It is set up that way, so if you get intermittent active codes, a tech can still pull them for a certain amount of time, to see what's going on..
If you know someone who has one of the old Harley Code readers... you can then erase the codes for good. There will be no historical codes, and no waiting for the proper number of engine cycles for the ECM to drop the historical codes...
Additionally, If you know someone with a powervision tuner, they can do the same... You don't need to have a tune license to use the PV Tuner to see or clear codes on any Delphi EFI Harley...
FWIW... I have a 2003 Heritage EFI... I bought it new in 2003, had an intermittent issue with a bad plug wire. So I bought and used the Harley code reader to check and clear that code... it does work
I eventually bought a PowerVision Tuner, to tune one of my other bikes. It would work for codes on my 2003, before I bought a license to use the PV to tune my '03 also.
As is.... it sounds like all is well and you can ride with confidence... and just wait for the historical codes to clear....
