Spoke rims
Old Jan 3, 2021 | 05:31 PM
mandd71974's Avatar
mandd71974
Default Spoke rims
I'm putting new tires on my 13' Heritage, 1st ones. Is it required to have the spokes checked anytime you install new tires?
Old Jan 3, 2021 | 06:43 PM
Tony_N's Avatar
Tony_N
Always a good idea to double check the spokes. You could have some that are loose or even broken.
Old Jan 3, 2021 | 07:12 PM
Imold's Avatar
Imold
You should at least give the spokes a tap with a screwdriver (round shank, not square corned) and see if they all have a similar ring. A thunk indicates a loose one. That's just a simple way riders have checked their spokes for decades, and got a lot of wheels through their whole life without spoke problems. Just have to be careful to get them tight enough, not real tight, you can break them. Best way is with a spoke torque wrench, but I've never seen one used, not even in a shop. Did you know the spokes at the top of the wheel take most of the bike's weight? The ones on the bottom just flex till the top has the weight. A loose spoke will be a hair longer than a tight one when weight is hung from it, means it's not carrying its full share of the load.
Old Jan 4, 2021 | 08:25 PM
Cap77's Avatar
Cap77
tagalong question if OP doesn't mind
when doing the spoke "tink" sound test, does it matter if bike is on kick stand or does wheel need to be off the ground?
thanks
..L.T.A.
Old Jan 5, 2021 | 01:48 PM
mandd71974's Avatar
mandd71974
Thanks Imold for the info. Will check mine this week.
Old Jan 5, 2021 | 04:15 PM
eighteight's Avatar
eighteight
thanks
..L.T.A.
Doesnt matter
Old Jan 5, 2021 | 07:21 PM
60Gunner's Avatar
60Gunner
I give my spokes a check every spring.
O-SiderRider
Apr 21, 2021 04:27 PM
billbrummett
Jun 1, 2020 04:19 PM
denman21
Mar 14, 2013 07:35 PM
Scooter68
May 25, 2010 04:44 PM
klf33
Feb 13, 2009 03:46 AM
