Going in for paint on Tuesday...
Old Feb 10, 2021 | 08:51 AM
hattitude's Avatar
hattitude
Originally Posted by MCSarge
Can't wait to see it. And, it will give you time to clean up that frame and those cylinder heads...LOL
I was thinking the same thing...
People will laugh, but I take off my tanks once a year, to really clean up the frame and the rocker covers.....!
When you're retired, and working on my bikes is a hobby, you have time for that kind of crap...
OP... can't wait to see that red/creme combo... as several have said, I can't picture it... but dying to see the result...
Old Feb 10, 2021 | 12:36 PM
kdryan's Avatar
kdryan
The closest thing I could find with the color combination I want is this CG model of a plane I did a few years back. The fading will make a world of difference on the transition, but you get the idea.
Old Feb 13, 2021 | 05:09 PM
gregeinsc's Avatar
gregeinsc
Taking your tank off that much you must have a quick disconnect setup. If so would you mind sharing?
Old Feb 13, 2021 | 05:34 PM
kdryan's Avatar
kdryan
I've never taken the tank off before and don't plan to again after this...
Old Feb 13, 2021 | 06:58 PM
hattitude's Avatar
hattitude
I know this wasn't intended for me, but I've had the tank off my '03 probably 6 or 7 times over the years since I bought it new....
FWIW.... it's not a hard thing to do....
To remove the tank, I put fuel line clamps on the crossover hose as close to the nipples on each side as possible... I then cut the hose between the clamps... A very small amount of fuel comes out, but it it easily absorbed by a rag...
After removing the tank, I put pieces of fuel hose over the ends of the cut crossover hose and then get all the residual gas out of the tank..
On my carb bike I first drain the tank via the petcock... and then get the residual gas out the cut crossover hose just like the EFI tank is drained.
After remounting the empty tank, I put a new section of crossover hose on the tank. I believe it's a 7" piece of fuel line...
Not really that big of deal.... I actually purchased a quick disconnect for the fuel line, but I didn't like the way it looked, changed the routing/length of the fuel line, and figured it wasn't really worth it.... I never put it on the bike.
Of course, after doing that numerous times, the tanks without a crossover hose like on my bagger, don't need to be drained and are super easy to remove, like a 15 minute job....!
William C
Feb 5, 2015 03:23 PM
William C
Nov 25, 2014 08:22 AM
hagger
The General Motorcycle Forum
Sep 29, 2013 01:54 PM
drrandall1
Mar 27, 2008 08:46 AM
MikesDad
Sep 8, 2007 10:32 AM
