Trans drain plug ,crossed
Old May 19, 2021 | 07:45 PM
Steve Kuzee's Avatar
Steve Kuzee
Default Trans drain plug ,crossed
New bike ,changing all the fluids and I cross threaded the trans drain plug !
I got it back in all the way with a new O ring and some thread sealer , BUT it did not get tight , just snug.
Will I make it 10 miles to a shop to have it repaired , or do I need to attempt it on my own?
2007 Softail Custom with 13000 miles
Help
Old May 19, 2021 | 10:00 PM
Will Belden's Avatar
Will Belden
Have you considered re-tapping it yourself? Just know the thread size / shape and buy the tap. And a new plug.
Old May 20, 2021 | 06:58 AM
ThePaintPirate's Avatar
ThePaintPirate
When I bought my Night Train, the previous owner stripped out the transmission drain plug so bad that when I removed it to change fluids all the threads just came out. I used Time Serts to provide a more permanent fix vs a helicoil, I like having a steel insert instead of a spring. It's quite a bit more expensive but it hasn't leaked a drop since. You want kit " 0122A" to fix any of your drain plug threads.
Old May 25, 2021 | 09:09 AM
Steve Kuzee
Thanks for all the tips and Ideas.
I bought a tap and plug 1 size up , at the local auto parts store
and retapped it , the plug went in well and tightened up.
40 miles and not a drop leaked !
Old May 25, 2021 | 09:12 AM
Will Belden
Originally Posted by Steve Kuzee
...bought a tap and plug 1 size up , at the local auto parts store and retapped it , the plug went in well and tightened up.
I wish more folks took the time to do this, good job! It can be difficult, but is the right way to approach it.
Why did you buy bigger, though? Generally, for a stripped bolt hole, usually can be the same size.
Dcz28
Apr 19, 2020 08:03 AM
Oregontowman
Sep 15, 2019 12:02 PM
Wishbone68
Jun 30, 2014 04:40 PM
fogey47
Apr 20, 2013 05:23 PM
kalamitty
Sep 4, 2009 01:13 AM
