Softail shock washer loose
Old May 31, 2021 | 01:48 PM
Softailman04's Avatar
Softailman04
Default Softail shock washer loose
One shock bolt has a loose washer. The bolt doses have a shoulder on it and the bolt is tight but the washer is loose. Will this hurt anything or the handling of the bike? Thanks for the input.
Old May 31, 2021 | 07:10 PM
Bluraven's Avatar
Bluraven
As long as the bolt is tight you’re fine.
Old Jun 1, 2021 | 04:45 AM
Softailman04
so this will not cause any handling issues or pulling to one side with the shock being able to move some on the bolt?
Old Jun 1, 2021 | 05:16 AM
RANGER73's Avatar
RANGER73
It might vibrate and sound like a Gremlin bell but it's fine.
If it bothers you add more washers, but the shock needs to
pivot so don't add so many that it's too tight.
Old Jun 1, 2021 | 05:55 AM
rigidthumper's Avatar
rigidthumper
Bolt is shouldered, because the shock has to be able to pivot in it's arc, or it would bind. The washer is there to prevent wear on the bolt head.
Old Jun 1, 2021 | 07:35 AM
Softailman04
I have not taken the bolt out so I am not sure if the shoulder is tight against the mounting surface. It might me tight because the treads are bottomed our.
sledgeb1
Apr 30, 2023 03:01 AM
Tobycatz
Mar 16, 2021 04:14 PM
Gunna48
Jun 21, 2011 04:18 PM
GEESE
Jul 25, 2010 09:34 AM
Gadgetmason
Jan 9, 2010 08:31 PM
