Crankcase pressure
Old Jul 1, 2021 | 06:40 PM
brakeless's Avatar
brakeless
Originally Posted by HDJoey
yes when i started it, no air was coming out at idle is that normal?
I don't believe you'll notice much if anything at idle. You'd need to crank it up a bit.
Old Jul 1, 2021 | 07:54 PM
hattitude's Avatar
hattitude
Thxs guys,
I put a straw in the breather hole and was able to suck air in. I purchased the new breather system from Harley, was gonna install it this weekend, should i abort or go through with it?
Are you talking about the breather assemblies that go in the rocker boxes....??? If so, it's not a difficult job, just time consuming. You have to remove the fuel tank, the rocker covers, the Breather assemblies, then reassemble everything....
If you have (can borrow) a leak down tester & a compressor... it will take about 15 minutes to do a leak down test and it only requires removing the spark plugs..
If it passes the leak down test, you know you need to dig deeper into the breather system.
If the leak down test shows bad rings, you can wait to replace the breathers when you take off the jugs for new pistons/rings...
Old Jul 2, 2021 | 08:27 PM
HDJoey's Avatar
HDJoey
Thank you,
Today my new oil cap blew off after 5 min of riding and broke into pieces on the floor, this is the 2nd one. Brought it to the dealer, I have no idea what else to do. They say some vent is blocked, ill let you guys know what they find! Keeping my fingers crossed that its nothing major 🤞
Old Jul 2, 2021 | 09:13 PM
hattitude's Avatar
hattitude
Thank you,
Please remember to report what they find...
The breather assemblies in the rockers, control the crankcase venting. They are pretty simple and I've not heard of them failing before.. Most breather assembly problems come from being assembled wrong with the rubber butterfly valve put on wrong, and actually then blocking the crankcase pressure from escaping through the head/breather bolts, etc... I'm very curious now, what they will find. Whether it's these breather assemblies themselves, or some of the hoses/passages after the breather assemblies they think are blocked...
FYI......
Forgive me if you already know this, but here are a couple of pics of the breather assembly in the rocker boxes. It's located between the rocker arms. The first pic is the breather assembly unit. It was just before I removed it, so the two bolts that hold it in place are missing. The second pic is with the top of the breather removed, exposing the rubber umbrella valve. That valve directs the pressure through the entire breather system.. from crankcase to air cleaner (or atmosphere in my case).
Old Jul 2, 2021 | 09:20 PM
HDJoey's Avatar
HDJoey
The breather assemblies in the rockers, control the crankcase venting. They are pretty simple and I've not heard of them failing before.. Most breather assembly problems come from being assembled wrong with the rubber butterfly valve put on wrong, and actually then blocking the crankcase pressure form escaping through the head/breather bolts, etc... I'm very curious now, what they will find. whether it's these breather assemblies themselves, or some of the hoses/passages after the breather assemblies they think are blocked...
FYI......
Thank you for the info and pics! Really Appreciated 🙂
I bought the 2 umbrella breathers you posted earlier. I was going to change them out but when i tested them using a straw i was able to confirm there functionality. Maybe they do need to be replaced, well see, i will definitely report back.
Thxs again 🙏
Old Jul 7, 2021 | 07:44 PM
HDJoey's Avatar
HDJoey
So just got the bike back from Harley and the problem was one of the umbrella valves that was not working anymore, they changed both of them and so far no more oil dip stick blowing off!!! So happy it wasn't the piston rings.
Good to know if anyone encounters the same issue, you can add the 2 umbrella valve replacement to the list of possible causes to crank case pressure.
Thank you everyone for there help!!🙏
Old Jul 7, 2021 | 07:48 PM
brakeless's Avatar
brakeless
That's good to know! Glad you got it taken care of.
Old Jul 8, 2021 | 09:09 AM
hattitude's Avatar
hattitude
Thanks for the update...
I would have loved to see how it failed... must have "stuck closed" to the metal frame.. or maybe the fiber filter got clogged up real bad with old oil...
This is the first time I recall hearing about them failing in a blocked position... good info to know..
Old Jul 8, 2021 | 02:02 PM
HDJoey's Avatar
HDJoey
I know, i had asked them to keep the old parts because I wanted to see how they failed also, when I got there they told me that it was thrown out😑
Thxs for all you help Hattitude!🙂💪
Old Jul 8, 2021 | 02:59 PM
brakeless's Avatar
brakeless
[size=16px]"when I got there they told me that it was thrown out"
Typical![/size]
strych9
Engine Mechanical Topics
Aug 1, 2020 03:10 PM
justgliding99
Oil Archive (no new posts)
Aug 15, 2018 07:24 PM
sidecar91
EVO
Apr 20, 2014 09:32 PM
chateau
Shovelhead
Jun 14, 2011 01:01 PM
Screw
Mar 25, 2007 02:25 AM
