41mm fork upgrade
Old Aug 19, 2021 | 07:13 AM
rauchman's Avatar
rauchman
Default 41mm fork upgrade
Greetings,
I ride a Dyna Switchback, which uses a 41mm fork, same as a Softail Slim.
I've added Racetech Springs and Gold Valve Emulators, which have improved the fork dramatically, but tweeking the settings requires a full tear down of the forks.
For you Softail owners, what have you done to upgrade your forks? Ideally, I'm looking for an option that allows for preload and damping adjustment (ideally, have the damping split between compression and rebound).
Thanks!
Old Aug 20, 2021 | 07:41 AM
WKNDS's Avatar
WKNDS
I did not change springs, all I did was Ricor Intimidators and Amsoil Shock Therapy.
Just those changes made a big difference.
https://www.ricorshocks.com/product-page/intiminators
The Ohlins NIX22 cartridges might work for you.
https://www.ohlinsusa.com/parts/2006...model=dyna-fxd
good luck,
T.
MegaFauna
Aug 4, 2015 03:54 PM
rauchman
Jul 28, 2014 08:52 AM
twiceretired
Sep 25, 2008 06:44 AM
James23
Apr 9, 2008 09:12 PM
grimm
Nov 9, 2007 05:52 PM
