Leaky carb
Old Sep 13, 2021 | 06:37 PM
Scrabopple's Avatar
Scrabopple
Stage II
Default Leaky carb
Bottom end of carb is leaking all over apparently while I'm riding and staining the motor. Smells like gas when parked.
Old Sep 13, 2021 | 07:50 PM
hattitude's Avatar
hattitude
You didn't ask a question, but rather just made a statement... are you bragging?
Seriously, that is one ugly carb. One of the ugliest I have seen. it's either leaking a ton, and/or been leaking for awhile....
If that were my bike...
I would remove the carb, completely disassemble it, and give it a thorough cleaning. You may consider borrowing or renting a sonic cleaner to get to all the passages in the throttle body. Short of a sonic cleaner, I would soak that carb body for a couple days in a good solvent, then with pipe cleaners and compressed air, clean out the passages as much as humanly possible. I would use emery cloth to clean up any stains in the throttle body and be sure the area where the slide operates is smooth and clean.
I would then reassemble it with all new wear parts: gaskets, o-rings, diaphragm, float valve, float, and probably even a new slide.
Here is a good reference for info and parts for the CV40 carb...
https://cv-performance.com/instructions-guides
Of course, if you are just bragging about it leaking, staining the motor, and smelling like gas.... great job..!
Old Sep 13, 2021 | 07:58 PM
Stiggy's Avatar
Stiggy
Amazon has S&S Super E carbs starting at $350.00
Old Sep 13, 2021 | 08:09 PM
Hey Man's Avatar
Hey Man
If it were my carb I'd pull it off and throw it away. Then put an S&S on it.
Old Sep 14, 2021 | 08:04 AM
eighteight's Avatar
eighteight
If he throws it away, send it my way
Old Sep 15, 2021 | 05:10 PM
Scrabopple's Avatar
Scrabopple
Stage II
I was definitely not bragging, lol. I think it's been leaking for longer than I realized and I'm finally getting around to fixing it. I really appreciate the input and I have plans to rebuild it. Other than that, it's a beautiful bike and runs great regardless of the carb leak. Thanks for the link also.
eightysix
Carburetor Related
May 28, 2015 07:30 AM
traildog
EVO
34
Aug 10, 2014 09:10 PM
Mcnasby
Sep 8, 2012 12:47 PM
chemcoffman
Jun 26, 2010 08:20 AM
raven28690
Ironhead
Mar 5, 2007 12:06 AM
