Hi I have a 14 breakout stage 4 103 dyno tuned with SESTP to 110/119.
the AFR map is all open loop (no red 14.6 cells in map)
i also have a power vision bought after the dyno tune that I used solely to change the VSS value after ratio change.
I noticed in the quick tools/ tweaks tab of the PV their is an option to toggle off closed loop and adaptive fuel.
Since my map is in open loop do I toggle closed loop and adaptive off so that the map is not changed ???
