Slipping in colder weather
Old Nov 12, 2021 | 08:32 AM
C0311's Avatar
C0311
6th Gear
Default Slipping in colder weather
2012 FXS Blackline with 13k miles that I've put about 800 miles on. Been riding for 12 years but this is my first FXS. Previous owner put on a Screamin Eagle air cleaner and tuner, and Vance and Hines longshot pipes. They had it dyno'd but I'm not sure if they used a preloaded map or created their own map.
When it drops below about 60 degrees, the bike feels like it's slipping when I'm running through the gears on the highway at 80-100% throttle. It's only a second or two after I shift, then it seems to pull normally. Since it only happens in colder weather, it makes me think that it's an issue with the tune and maybe not with the transmission. I greatly appreciate any thoughts on where to start looking.
Old Nov 12, 2021 | 08:34 AM
bad tappets's Avatar
bad tappets
Sounds like a clutch issue. Adjust clutch see if that helps.
Old Nov 12, 2021 | 09:55 AM
smitty901's Avatar
smitty901
Does sound like a clutch adjustment is called for. That few miles hard to except that clutch would be wore out.
Old Nov 12, 2021 | 10:03 AM
C0311's Avatar
C0311
6th Gear
I'll take a look at it, thanks. Adjusting the clutch seems pretty straightforward.
Old Nov 14, 2021 | 05:30 AM
C0311's Avatar
C0311
6th Gear
Hmm so that didn't seem to fix it. I took all the slack out of the clutch cable, loosened the lock not on the clutch adjustment screw, tightened the screw until I felt resistance, then backed it out half a turn and tightened the lock nut. It definitely slips in 5th and 6th gear, even when I give it only 60-70% throttle. Wonder if I should just replace the clutch. Or should I start with a heavy duty stock clutch spring?
Old Nov 14, 2021 | 06:28 AM
smitty901's Avatar
smitty901
For a clutch to fail at that low of mileage is unheard of. There is more going on with it. You will need to find out if something in the clutch has fail.
Get a service manual collect the tools and open it up. Don't go buying arts until you find the problem.
Old Nov 14, 2021 | 06:44 AM
IronAss's Avatar
IronAss
I've not paid any attention to the newer bikes but assume they still use a compensating sprocket?
Maybe the compensator is slipping under load?
I probably need to go take a dump and think about it. I do my best thinking when I'm pinching off a loaf.
Old Nov 14, 2021 | 06:55 AM
C0311's Avatar
C0311
6th Gear
Solid plan haha.
​​​​​​​For a clutch to fail at that low of mileage is unheard of. There is more going on with it. You will need to find out if something in the clutch has fail.
Luckily the previous owner bought a manual. I'll take the clutch plates out and see if anything looks off.
Old Nov 14, 2021 | 07:50 AM
smitty901's Avatar
smitty901
2012 with that low of miles compensator would be low on the list. With a used bike you never know what was done to it or not done. One step at a time to zero in on the problem.
How does Primary lube smell and look?
Old Nov 14, 2021 | 08:11 AM
Iceman24's Avatar
Iceman24
If you're going @ 80-100% throttle when shifting...probably burnt out clutch (IMO). Pretty much drag racing when you're taking off...
