Tips needed exhaust torque
Old Nov 15, 2021 | 10:20 AM
ricks2524's Avatar
ricks2524
Default Tips needed exhaust torque
Tell me how you can properly torque the front cylinder exhaust flange. I'm sure someone here has a secret answer. Thanks
Old Nov 15, 2021 | 10:48 AM
QC's Avatar
QC
Spin the nuts on by hand till contact is made with the flange, apply a 1/2" socket preferably using a 1/4" extension to get past the downtube on the upper nut, then tighten 1 turn at a time, alternating between upper and lower nuts until tight. And not Gorilla tight either. I think the spec is 90 inch pounds, but I don't use a torque wrench on these. You'll know when they're tight.
Then ride the bike through a couple heat cycles and retighten.
Old Nov 15, 2021 | 11:21 AM
hattitude's Avatar
hattitude
The above technique should work...
I've always had success following the service manual sequence:
a. Tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm).
Tighten the bottom
nut to 100-120 in-lbs (11.3-13.6 Nm).
Final tighten
the top nut to 100-120 in-lbs (11.3-13.6 Nm).
b. Tighten the bottom nut of the rear cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm).
Tighten the
Final tighten
the bottom nut to 100-120 in-lbs (11.3-13.6 Nm)
IMHO, the best results come from using the following tips:
Use the appropriate gasket for the exhaust header design, where it fits into the exhaust port at the head.... ie: the cone shaped exhaust headers seal best with the OEM tapered, collapsable gaskets. The flat, square exhaust headers seal best with flat, square "Screamin' Eagle'" style exhaust gaskets.
Always re-torque after a few heat cycles.
Always ensure the exhaust clamp retaining clips are in good shape. If they are twisted or warped, they won't allow the clamps to properly pull the header into the exhaust port against the exhaust gasket. On poorly designed, or off-brand exhaust headers, I've know people to solve leaking exhaust at the head, by doubling up the retaining clips..
Old Nov 15, 2021 | 12:39 PM
fat00boy's Avatar
fat00boy
If your shields are still on, removing them makes it easier. If your tightening the whole system, hang the system loosely but in the proper place and start at the head and work your way to the rear.
Old Nov 15, 2021 | 01:51 PM
Clammy's Avatar
Clammy
As has been stated, it's a light torque spec. I use a long 1/4" drive extension, with a 1/4" drive 1/2" socket. Fits up perfectly.
I follow the FSM torquing instructions.
Cheers!
Old Nov 19, 2021 | 06:37 AM
Roy K's Avatar
Roy K
2nd Gear
Default Baffle packing
I have a 2008 Heritage, stage 1, with the Khrome Werks 3" Slash cut mufflers.
I recently removed the baffles to compare tone and the packing was destroyed.
I realized I prefer the tone WITH the original packing vs. without packing and now cannot seem to identify their packing and wrap "blend", as it looks like multiple layers.
Aside from the photos looking like a decaying bird carcass, any idea how I can reproduce this type of packing/wrap to restore the original tone?
It looks as if it begins with a glass wrap, followed by a glass mat(about 1/2" thick), and then all wrapped with a paper type material, which I have not seen anywhere.
Old Nov 20, 2021 | 08:13 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
The only thing I can add is that as an engineer is I believe in using a torque wrench and using anti-seize compound on the threads.
Old Nov 20, 2021 | 08:32 AM
QC's Avatar
QC
It look as if it begins with a glass wrap, followed by a glass mat(about 1/2" thick), and then all wrapped with a paper type material, which I have not seen anywhere.
J&P Cycles and probably a couple other places on line have exhaust baffle wrap.
swansonj6
Jun 6, 2016 01:13 PM
Nocturnalnature
Jan 25, 2013 11:07 AM
s.ga.rider
Aug 22, 2011 12:59 PM
stbobau
Nov 2, 2010 09:34 AM
forever young
Apr 9, 2008 08:48 AM
