Tank overflow line
Old Nov 28, 2021 | 04:59 PM
Wrechar's Avatar
Wrechar
Default Tank overflow line
All,
Just a sanity check on the requirements for the tank overflow line on a 2002 fxst. I can't find anything on it in the service manual.
The line itself doesn't look like fuel line. It runs from the right side tank down the main chassis tube and crosses over at the carb to the left side past the oil tank and seems to just dump any overflow between the back plastic wheel guard and the transmission near the ground.
Does this need to be such a long path? Is an alternate path sufficient and is a regular 1/4" fuel line good enough?
Thanks.
Old Nov 28, 2021 | 09:26 PM
megawatt's Avatar
megawatt
I'm sure that you can end the hose anywhere you don't mind gas to drip if the tank overflows.
But 1/4" fuel hose can be thick walled and might give you grief fitting it through tight spaces on it's way to the ground.
I'm not certain it's a 1/4" nipple on the tank. It could be 3/16".
Anyway, you can get fuel overflow hose (it's a thin walled hose) from most motorcycle shops that sell dirt bike gas tank vent hose.
That stuff comes in different colors if you have a need.
That is what I used for my overflow from the right tank on an '87 FXSTC.
Old Nov 29, 2021 | 08:58 AM
hattitude's Avatar
hattitude
Originally Posted by Wrechar
All,
Thanks.
That hose is to vent vapors from the fuel tank....
As you can see in this pic, your vent hose is two parts...... #19, a rubber piece from the tank nipple to the hose (more of a tube) and the tube itself, #22. It should go through a vapor valve (#28) down by the trans/frame.... the CA models actually have the vented vapors go through a charcoal canister filter in that area..
It is run to that location to facilitate the CA emissions bikes and so the escape of tank vapors isn't usually smelled by the rider.... I guess you could move it to anywhere you want, and 1/4" fuel line would probably be overkill. The hose only needs to match the ID of the tank nipple. I suspect that if you bypass the vapor valve (#28), then in hot weather, or a full tank with the engine hot, you could get a continuous smell of gasoline from the vent...
Old Nov 29, 2021 | 11:32 AM
Wrechar's Avatar
Wrechar
@hattitude and @megawatt - thanks for the info. Just what I was looking for.
W
Old Dec 6, 2021 | 10:06 PM
megawatt's Avatar
megawatt
Whatever you do I hope it works out for you.
crabio
May 22, 2016 04:48 PM
baldeagle503
Mar 14, 2014 09:34 PM
Austin Dave
Jun 1, 2012 10:18 PM
92oldskoolxlh
Apr 4, 2012 10:02 AM
rustyed
Jan 6, 2007 12:43 PM
