No, I didn't tape off the fins. I just painted them and then took the paint off the edges... don't even remember what I used now (1978 was a long time ago). Taping all the stuff is a pain, but the details are what makes it or breaks it, so take your time and it will pay off. One trick I use on cars for hoses and wires that I don't want paint on is to just wrap them in aluminum foil. Easy to work with, stays in place, and easy to get off when you're through.
One thing you might ask your paint store (automotive paints) is about prepping aluminum. Paint doesn't like to stick to it unless it's prepped.
They'll have an acid in a spray bottle that works. You leave it on a couple of minutes and hose it off. I don't know what acid it is but I've heard that it's just muriatic acid like you use in a swimming pool to adjust the ph. The acid etches the metal (you can't see it, it's too fine) so the paint will stick.
