engine swap
Just in case you have not done both of these two important items!
Be sure to add an Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post with your USER name.
And most importantly a Signature Line in your USER set up for your bike model, year, and all the letters that Harley recognizes it with that others see at the bottom.
This enables others to know your exact model if you ever ask a question or another member interested in it may ask you a question about it.
Your all set.... Enjoy the ride! ______________
Good Luck!!
hello everybody my name is nuno and im from south texas and i own a 2003 fatboy 100th anniversary edition and few month back i purchased a hd 103 engine from the hd dealership in austin tx, come of a 2016 street glide so i was told by the service and parts guys there, and i was thinking about upgrading my twin cam 88 with this 103 engine i also purchased a hd six speed transmission from an 08, model my thing is will this combination work the 103 engine with a earlier model 08 six speed together if i were to do the engine swap any info on this will be very useful . or should i just build a bike with this set up? i kinda want my fatty with more horses !!
The Twin Cam "A" engine/trans combo used in Touring bikes is different from the Twin Cam "B" engine/trans combo used in Softail bikes.......
The frames and engine/trans mounts between a touring bike and a softail are different.... The transmission housings, and how they mount to the engine and rear swing arm, are different between an "A" engine and a "B" engine.
I have a friend who says, "Anything is possible with enough time and money".... That engine/trans swap would not be possible without major modifications, an awful lot of time, and a rather large pile of money.....
You'd be much better off getting a Stage IV kit for your FatBoy from one of the vendors on this forum, that could set you up with good parts that are compatible and work well together to achieve your power goals.... It would be easier, cheaper, and more satisfying in the long run...
I'm curious why you bought a 103" Twin Cam "A" touring engine when you own a softail...??? Regardless of the reason, you can either build a touring bike around that engine, resell it to someone with a touring bike looking for that type engine, or put it on display as wall art...
Good luck with your decision...
