Used Fat Boy questions
Old Feb 25, 2022 | 04:04 PM
ChiefBlueMeanie's Avatar
ChiefBlueMeanie
2nd Gear
Default Used Fat Boy questions
Howdy all,
I'm looking at used Fat Boys and found one locally. It's a 2009 with 29k miles - what should I look at specifically on this bike? Far as I can tell from the photos it's all stock. I had a '97 FXDL years ago but am not familiar with Fat Boys.
Thanks in advance.
Old Feb 25, 2022 | 06:03 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Welcome to The HDF's!
Old Feb 25, 2022 | 09:24 PM
hattitude's Avatar
hattitude
Originally Posted by ChiefBlueMeanie
Howdy all,
Thanks in advance.
That should be a solid bike, and you should get many years and miles from it with good maintenance habits...
A few things pop into my mind, I'm sure I'll miss a couple others...
The good:
It has the upgraded cam plate and cam tensioners. It has hydraulic tensioners with roller chains instead of it's predecessor, spring tensioners with link chains... Should be good for well over 50K miles... many hit 100K miles without issues, unlike the spring tensioners
You still have the "B" series Harley lifters which are a far cry better than the "C" lifters which came out in 2010 or 2011.. no need to ever change them out unless they start making noise...
The bad:
You still have the INA Brand cage-style inner cam bearings, but you have the B-168 bearings, which have far fewer reported failures then their predecessor, the B-148 size INA brand bearings. No need for immediate action, but if you are ever inside the cam chest for any reason, like a cam change, most will upgrade those to the Koyo-Torrington captive needle style bearing.
Harley upgraded the compensator in 2007. The first few years there were many failures... If you are all stock or Stage I, you could get many miles from the version you have, but it is a weak link. Should you need to replace it, there is a newer style, I believe they call it the Screamin' Eagle Compensator for those year bikes, that will be better than the OEM part #.
Like any used bike, look it over well, and as long as it's in good shape and has been maintained well.... it should give you good service..
Good luck with your bike search...
Old Feb 26, 2022 | 05:52 PM
ChiefBlueMeanie
2nd Gear
Deleted post
Old Feb 26, 2022 | 05:54 PM
ChiefBlueMeanie
2nd Gear
The good:
The bad:
Thanks much, this is exactly what I was hoping to find. I'm not familiar with the 96B motor, so it's hugely helpful. I wasn't sure what the compensator was, but after a few YouTube videos I'm an expert <g>
Old Feb 26, 2022 | 06:04 PM
hvacgaspiping's Avatar
hvacgaspiping
The good:
The bad:
`Couldn`t have said it better myself... Note my sig bike...
Timbo64
Apr 26, 2020 12:55 PM
user 19749720
Sep 17, 2019 09:27 PM
Zedder
Jul 11, 2015 11:24 AM
JAFlanders
Softail Pictures
Oct 14, 2013 01:58 PM
reddog8145
Sep 26, 2009 10:50 AM
