Error 562
Old Feb 27, 2022 | 04:25 AM
Joedude's Avatar
Joedude
Default Error 562
Hi all
need help badly. My 2006 softail Springer is giving me error 562 with check engine and battery icon on .
ive replaced to new battery , same again.
now replaced the regulator same again.
Ive checked at battery while i got the code with bike running and get 14.1 volts , so that means my charging is supposed to be good.
any help would be appreciated. I do not want to replace stator as reading was good on acv coming out.
Any ideas.
Thanks
Joe
Old Feb 27, 2022 | 04:38 AM
Jackie Paper's Avatar
Jackie Paper
What's 562? Have you cleared codes to recheck?
Old Feb 27, 2022 | 04:48 AM
Joedude's Avatar
Joedude
yes cleared po562 but comes back. Its low voltage
Old Feb 27, 2022 | 04:54 AM
Jackie Paper
Turn on the ignition with lights on. Turn it off. What is voltage now on cables at battery and at lead of battery terminals?
With meter on terminals, crank to start. Watch carefully and see what voltage drops to.
Old Feb 27, 2022 | 07:19 AM
Joedude's Avatar
Joedude
just did that its now 12.76
Old Feb 27, 2022 | 07:23 AM
Joedude's Avatar
Joedude
when i started its 10 v.
Old Feb 27, 2022 | 07:24 AM
Jackie Paper
Reread my post carefully and post back. So far I haven't a clue.
Sorry, didn't see second post. Remember, you can edit post...
Still scratching my head. Bike is good. Problem is, it doesn't know it. Must be a connection on further.
Will get back after I read diagnosis tree for error code.
Maybe by then, a real expert will wake up and chime in.
Old Feb 27, 2022 | 07:32 AM
Joedude's Avatar
Joedude
Dont understand it, did a trip 2 months ago to Italy, did 2000 miles had no issue. How come charging system checks good, battery is good. Still i get code po562 and check engine and battery icon on , what else can be causing error.
Old Feb 27, 2022 | 07:33 AM
Joedude's Avatar
Joedude
thank you for your help..
Old Feb 27, 2022 | 08:02 AM
Jackie Paper
This code is generated when voltage drops below 11 at 2000 rpm for over 5 seconds.
Of course, bike will still run at that
Connects at ignition switch dirty, the on/off on the bars, a bad wire, connection at ecm relay or ecm fuse, the power ground coming off ecm. Or the ecm plug.
​​​​​​Lot of variables like milage, bike been in wreck, flooded under water, weather and condition bike is subjected to.
Odd accessories added to bike or modifications .
