97 Fatboy Choke Question
Old Sep 21, 2022 | 09:06 AM
BlazinBobby's Avatar
BlazinBobby
3rd Gear
I think the throttle screw or clothes pin are gonna be my best option. Snapped a photo this morning, I didn't see anything that looked to be adjustable, the clockwise/counterclockwise twist doesn't do anything.
Old Sep 21, 2022 | 02:07 PM
vtbigdog's Avatar
vtbigdog
And that is a perfect picture...of the nut..
Q: I have a 2000 FLHT with a carbureted Twin Cam 88. The carburetor works fine, but the choke will not stay engaged unless the **** is physically held out. It immediately slides back to the off position if you let go. The choke operates properly, but holding the choke out is annoying on cold mornings when it takes several minutes for the engine to warm up. Any ideas to remedy this problem would be greatly appreciated.
A: Carefully try tightening the cable. Look behind the Harley enrichener cable bracket. You will see a zinc plated nut. Tighten this ONLY SLIGHTLY. Just a nudge will do. If you over tighten, you will break the cable, so be very careful. You are tightening a steel nut, over a plastic, hollow, shaft.
Old Sep 21, 2022 | 02:30 PM
RANGER73's Avatar
RANGER73
Rtfm
Old Sep 21, 2022 | 03:22 PM
vtbigdog's Avatar
vtbigdog
Originally Posted by RANGER73
Rtfm
Seriously, is that really necessary?
Old Sep 21, 2022 | 05:18 PM
BlazinBobby
3rd Gear
Well speaking of RTFM, here it is. Does not help, other than implying that it should stay out which it does not so here we are:
COOL ENGINE
Outside Temperature Warmer than 60°F
Turn the fuel valve to the ON position (carbureted models). BE
SURE THROTTLE IS CLOSED. Pull enrichener **** to full
out position. Turn the ignition switch on and press starter
switch to operate the electric starter.
1. See Figure 3. After initial 15-30 second warm-up, ride for
1 minutes or 1/2 mile with enrichener **** in full out
position.
2. After 1 minutes or 1/2 mile, push the enrichener **** in
to the 1/2 way position. Ride 1 minutes or 1/2 miles.
3. After 1 minutes or 1/2 mile, push the enrichener ****
fully in.
Old Sep 21, 2022 | 06:00 PM
RANGER73's Avatar
RANGER73
He didn't say if he looked in The FM and it should be in there.
So yes. There's even an emoji provided by HD Forums just for a situation like this.
Wanna see it?
Old Sep 21, 2022 | 07:38 PM
vtbigdog's Avatar
vtbigdog
Wanna see it?
Mayybe he is a newbie and trying to learn....like you did at o e point in time. We all can't be as smart (***) as you. Just sayin...
Old Sep 21, 2022 | 08:22 PM
RANGER73's Avatar
RANGER73
First thing I do is try and figure it out myself.
GOOGLE, YouTube, the frigin' manual.
Before I ask a question on a public forum.
But hey, you do you.
His question was answered in the chapter on blinker fluid.
Old Sep 22, 2022 | 08:45 AM
BlazinBobby
3rd Gear
There is always an RTFM guy spends more energy bitchin than helpin.
Thanks for the pointers all.
Old Sep 22, 2022 | 09:05 AM
fat00boy's Avatar
fat00boy
To adjust the tension on the cable. (1) loosen the nut behind the bracket, (2) tighten the plastic knurled nut to desired tension while holding housing, (3) tighten nut behind bracket. It's in the service manual.
jtb4ever
Jul 11, 2021 02:03 PM
yooperbigdog
Jul 21, 2017 06:06 AM
BigPimp
Nov 1, 2013 08:06 AM
FatBoy94
Oct 16, 2007 02:40 PM
fatusboyus
Mar 9, 2007 04:53 PM
