'05 Springer Softail front wheel question
Old Oct 10, 2022 | 11:17 AM
greenhell's Avatar
greenhell
Default '05 Springer Softail front wheel question
I've got an '05 Springer Softail FXSTSI and would like to switch from the 2.15 thin front tire and wheel to a 21"x 3.5 front tire and wheel. Is switching out to a wider front tire possible with the springer forks?
Old Oct 10, 2022 | 11:30 AM
Tampa Fatboy's Avatar
Tampa Fatboy
delete
Old Oct 10, 2022 | 01:24 PM
Screamin beagle's Avatar
Screamin beagle
I dont know if it will fit but I had an 06 springer custom and I hit a pothole a bent the front rim. I found a used rim that came from a 06 night train...thought I caught a break lol. Nope...that was my first lesson in hub offset. Those two were not the same. I had my inner hub laced to the new outer rim with the correct offset...just be careful with what you buy.
Old Oct 11, 2022 | 11:07 AM
back again's Avatar
back again
Trying to remember but the 3.5 - 21 wheel fits the stock fender but I think you’re limited to a 100/70 tire. The110 hits the fender mounts.
Old Oct 14, 2022 | 09:39 AM
greenhell's Avatar
greenhell
Thank you! Knowing that, I'll be shopping for a new wheel and tire. I love my Springer but I think adding a wider/beefier tire to the front will balance out the look, imo.
Old Oct 14, 2022 | 09:40 AM
greenhell's Avatar
greenhell
Thanks for the heads up. I'll make sure the new wheel fits the Springer.
Old Oct 23, 2022 | 04:36 PM
back again's Avatar
back again
Going to back the size down from 100-90 to 90/90 greenhell. Memory is what it used to be. That’s what I run on my Train. Sorry for the bad info. G.
Old Oct 23, 2022 | 04:38 PM
back again's Avatar
back again
HarleyCanada
Feb 3, 2013 12:48 AM
scorchedearthpolicy
Jun 4, 2012 05:06 PM
Clokey82
Wheels/Tires
Apr 30, 2012 10:56 AM
JWOC
Sep 9, 2010 08:28 AM
capttawes
Apr 12, 2007 12:56 PM
