Front brake light not working
Old Nov 28, 2022 | 07:38 PM
nweb992000's Avatar
nweb992000
Default Front brake light not working
2006 FXSTSi brake wire has a voltage drop. It's probably in the switch itself. It looks like a PITA to fix. Has anyone fixed the handbrake switch, or can I just replace it?
Old Nov 28, 2022 | 07:48 PM
M Oclaf's Avatar
M Oclaf
Default Can’t help
Only have a rear brake, what is the front brake for? Backing up?
Old Nov 28, 2022 | 08:11 PM
commando57's Avatar
commando57
Several youtubes on this. You might get lucky. I did.
Old Nov 29, 2022 | 02:30 AM
S.D.M.F's Avatar
S.D.M.F
Search : "harley front brake switch replacement" on Youtube. A few videos to help diagnos and replace if need be.
Old Nov 29, 2022 | 02:40 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I replaced my 04. Just blanket the tank and go slow and take pictures. I didn't fish your part but later ones just plug.
Mine was cut wires, soldier, wrap a couple tight wraps of plastic tape and shrinkwrap.
I as usual then sealed ends of shrink with rtv black.
There is a little V bronze spring clip that holds switch in place. Be sure it's in place. Tight working in that little clam shell.
Old Nov 30, 2022 | 06:11 AM
Bluraven's Avatar
Bluraven
I just cut the old switch out and soldered in a new switch using the existing wires.
skewzme
Electrical/Lighting/Alarm
Sep 1, 2020 07:45 PM
CSM Sandoval
Dec 19, 2012 02:56 PM
twistedbluesteel
Jul 23, 2012 01:56 PM
frenchbiker
Oct 26, 2011 05:25 PM
95Heritage
May 27, 2007 09:46 AM
