Break light works with front brake, but not back brake
Old Aug 31, 2020 | 06:00 PM
skewzme's Avatar
skewzme
Default Break light works with front brake, but not back brake
Brake tail light works with the front brake, but not with the back brake.
What would you check first?
Old Aug 31, 2020 | 06:09 PM
RANGER73's Avatar
RANGER73
There's a pressure switch in the rear brake line, It's either the wire fell off or the switch is bad.
Old Aug 31, 2020 | 06:19 PM
Pale Horse Rider's Avatar
Pale Horse Rider
exactly what he said. Just happened to me.
Old Aug 31, 2020 | 06:53 PM
deez nuts's Avatar
deez nuts
I have the same problem on a 2000 Dyna FXDS-Conv. Guess I'll be looking for this switch and checking the wires and replacing as needed.
Old Aug 31, 2020 | 07:20 PM
skewzme's Avatar
skewzme
Appreciate the quick reply....
I probably should have also mentioned its a custom tail light I rewired myself.
Does anyone know if the front and rear brakes have separate wires going to the tail light?
Or, is there just one brake light wire that sends a signal from both places?
Old Aug 31, 2020 | 08:03 PM
CoolBreeze3646's Avatar
CoolBreeze3646
If it is not what was mentioned above with the brake light switch, you should look at the wiring diagram in your HD Field Service Manual, it is your friend and will help you accomplish many things.
There are 2 separate and distinct switches, one for the front, one for the back, they both feed into the wiring for the rear brake light; unless you custom rewired it, then you are on your own as to what is wrong. Good Luck.
Old Sep 1, 2020 | 11:17 AM
EVOrider's Avatar
EVOrider
Are you running the stock size tire or lowered the suspension?
Taller/wider tire.....sometimes rub on hard bumps and eat wiring under the fender.
I’ve seen that more than once....
Old Sep 1, 2020 | 03:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the brake light works with the front brake, it is not wiring under the fender...
Old Sep 1, 2020 | 04:00 PM
kel03's Avatar
kel03
This is like Ground Hog Day !
Old Sep 1, 2020 | 07:45 PM
EVOrider's Avatar
EVOrider
Apparently I can’t read or comprehend...duh😜😜
drsnipes
Dec 3, 2023 01:18 PM
FLYING_BURRITO_BROTHER
Sep 3, 2020 01:03 PM
moblmowr
Feb 29, 2008 08:00 PM
Jonny Cannon
Jul 11, 2007 09:19 AM
Skip
Aug 12, 2006 01:48 PM
