Plug and Play LED headlight bulb hi beam stops working after a few minutes
I have put back the old H4 halogen bulb, and that bulb functions properly.
What is the likely culprit??? Heat (from the bulb itself)? Voltage? I notice some of the plug and play LED headlight bulbs have an in-line device, the ones I purchased do not.
Thanks for any advice.
Last bulb was also a Pathfinder LED H4, purchased from J&P Cycles, link: https://www.jpcycles.com/product/901...umens-led-bulb
and the thermal link is cutting out. It resets itself when the bulb cools off.
Plus, those aren't compatible with the fluting of a motorcycle lens.
Try a deeper bucket.
https://www.ebay.com/itm/AUXITO-9003...edirect=mobile
1. I discovered that even on low beam, with the ignition on but engine off, within 1 hour the bulb goes off... this happens with either of the new LED plug and play bulbs I bought. It also happens after disconnecting from the battery the few accessories/accessory connections (cell phone, gps, heating jacket, battery tender) I have installed.
2. Eureka! I bought an inline resistor, it's 6 ohms, 50 watts. It has h4 type connectors at both ends, so it too just fits onto the existing connectors. With the resistor connected, the LED bulbs function perfectly.
What I think that means is that the canbus is being fooled into thinking that the old style bulb is still installed, at least that's the best explanation I've found on the net.
That still leaves me with some questions..1) is there another, more elegant solution, that is, can I otherwise trick or train the canbus or eliminate the problem without having this sizeable (or even any) transistor to deal with... it gets very hot. 2) why doesn't this seem to happen with others with the same or similar bikes to mine?
Thanks!
Check with the Company's that you bought the lights from for their recommendations for them.
FYI The LED's don't produce the heat that regular lights do or use as many Amps.
KenK
