Breakout no power to fuel pump
Old Mar 1, 2023 | 10:28 PM
Deadly dave's Avatar
Deadly dave
Stage III
Default Breakout no power to fuel pump
Hi all
dave from Western Australia here im new to the group but have been reading posts for a while
ive just bought a 2013 breakout basket case and am slowly piecing it back together everything I'd working fine except I can't get the fuel pump to work (not getting a power feed from ecm not even at first power up) the bike will run fine if I power up the pump ,it does have a code up B2117 ( fuelpump output shorted high ) that I can't trouble shoot
New pump
Fuses are good
Stands up
out of gear
Wireing from pump to ecm continuity is good
Run stop switch turns bike off (when bike is running on supplied power)
# Info that may help
no co2 sensors hooked up
Fuelpump has continuity across the 2 terminals when not plugged in
Only has main 50amp fuse and 2 15amp fuses on whole bike under seat no relays(that i can find anyway)
Any help greatly appreciated
Cheers
Old Mar 2, 2023 | 05:15 AM
S.D.M.F's Avatar
S.D.M.F
https://serviceinfo.harley-davidson....3093b8f2e!!1!3
Old Mar 2, 2023 | 07:10 AM
Deadly dave
Stage III
Yea can see all the schematics but the feed comes from the ecm so I think it is either in the esm or a interlock I havnt thought of
cheers tho
Old Mar 2, 2023 | 08:51 AM
hattitude's Avatar
hattitude
I don't enjoy, neither am I really good at electrical issues... but I have struggled through a couple... so this isn't coming from a electrical CanBus expert....
If I read this correctly, you have powered the pump itself, so we know the pump is good, correct...?
With that code, it would suggest the power is not getting from the ECM to the pump....
Have you measured the output at the ECM to fuel pump pin with a volt meter to confirm ECM outout...?
If you have output from the ECM, might try running a wire from the ECM pin directly to the pump, taking the bike's harness out of the equation... that would confirm a problem with the wiring along the way between the two...
Good luck and report back when you find the issue...
Old Mar 2, 2023 | 09:05 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Fuel pump is powered by BCM, not ECM.
Old Mar 2, 2023 | 09:10 AM
Deadly dave
Stage III
yea I've pined it out back to the bcm pin f4 i have a 5v pull up voltage just not a signal voltage
the pump is brand new yes
Old Mar 2, 2023 | 09:22 AM
hattitude's Avatar
hattitude
Well, you seem to be on top of it....
At this point I would have to get professional help.... So someone smarter than me will have to help you decipher the results of your testing and/or suggest the next course of action.....
cstorey
Sep 19, 2017 03:59 PM
Jason Anderson
Feb 6, 2016 01:13 PM
no smoking please
Apr 20, 2015 04:19 PM
monster715
Feb 21, 2015 02:34 PM
sicksuperglide
Jan 2, 2009 09:17 AM
