Engine idle
Old Apr 15, 2023 | 02:21 PM
stepbill's Avatar
stepbill
Default Engine idle
I noticed that when my bike idles, it is around 950 and bumps to 1000 sometimes but normally stays around 950. The check engine light is also on and made an appointment to have it checked but I was wondering if this idle is normal. New to HD so don't know what to expect.
Old Apr 15, 2023 | 03:16 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Look at your owner's manual under EITMS and see if that is what is happening.
https://www.lawabidingbiker.com/86/
Engine light, may want to check for codes, dealer will resolve as it is under warranty.
https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Apr 15, 2023 | 05:50 PM
stepbill's Avatar
stepbill
Thanks Cool Breeze, that's what it was. I turned it off and the check engine light even went out. Thanks again!
Old Apr 15, 2023 | 06:32 PM
CoolBreeze3646
Even though the check engine light went off, it may be a good idea to see what codes if any are there. If you have codes, write down what they are and clear them to see if they come back. If they don't come back you are good to go. These newer bikes have all sorts of stuff going on computer and electrical wise and will tell you if there is an issue.
Old Apr 18, 2023 | 09:04 PM
IBE's Avatar
IBE
when you take it to harley tell them about it and they will check your code history no need to write them down.
Dudepants
Aug 21, 2021 04:19 PM
Uboofer
Jul 26, 2015 06:07 PM
gbuss5
Jul 14, 2015 09:42 AM
berniemc
Jun 16, 2015 10:06 PM
Jerry Nokes
Engine Mechanical Topics
Oct 29, 2014 09:50 PM
