Another Dreaded Click, Click...
Old Jul 19, 2023 | 08:44 PM
  #41
Tom H's Avatar
Tom H
Aw crud!!
Just a thought. On another brand bike with a Bosch starter. On the bench, the starter would spin what seemed like fine. Back in the bike, would not turn the engine. Turned out that under load the starter was weak. Cleaned all the built up crud out of it and new brushes, all was well.
Could you have that issue??
Good luck!!
Tom
Old Jul 19, 2023 | 08:48 PM
  #42
mikey95hd's Avatar
mikey95hd
Originally Posted by Jackie Paper
That's also reference a check when the the click from the starter draws. That should drop to 9.7 or so. . If it doesn't, be sure first relay is getting battery voltage to starter checking at starter to eliminate the first small relay as bad.
The relay clicks. So it's getting voltage. I think it's bad, got a new relay on its way. It's 28 years old.
Old Jul 19, 2023 | 08:53 PM
  #43
mikey95hd's Avatar
mikey95hd
Originally Posted by Tom H
Aw crud!!
Good luck!!
Tom
I'm leaning towards that outcome, since it turns with no load, and when putting a load on it it fails.
At least with my original clutch, when you pull the lever in gear it rolls now, without the engine turning.
Of course the rebuild starter has no warranty.
Old Jul 19, 2023 | 08:56 PM
  #44
Jackie Paper's Avatar
Jackie Paper
You really need to attempt to prove something is bad. There two of those same relays in my fuse box.
Old Jul 19, 2023 | 08:57 PM
  #45
mikey95hd's Avatar
mikey95hd
There's only one on this bike.
Old Jul 20, 2023 | 12:40 AM
  #46
Jackie Paper
Mines FI.
Old Jul 20, 2023 | 12:42 AM
  #47
mikey95hd's Avatar
mikey95hd
Mines FI.
As far as I can see.
Old Jul 20, 2023 | 05:28 AM
  #48
Jackie Paper
Mine has a start and a separate system relay. Both identical number. Side by side under seat.
Old Jul 20, 2023 | 07:36 AM
  #49
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Time for some actual troubleshooting.
Get out your digital multimeter.
Read the voltage at the small terminal on the starter solenoid when the start button is pressed, note: do not unplug the wire.
What is the voltage reading?
Old Jul 20, 2023 | 07:48 AM
  #50
HeritageBrads's Avatar
HeritageBrads
My money is still on the battery
What does the voltage drop to when you hit the starter button?
Does it collapse ?
