Another Dreaded Click, Click...
Old Jul 18, 2023 | 06:23 PM
mikey95hd's Avatar
mikey95hd
You have done everything needed, time to reassemble and give it a try.
Will reassemble everything tomorrow, should I leave the outer primary off, to see if the jackshaft is engaging the clutch?
Old Jul 18, 2023 | 06:52 PM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by mikey95hd
Fully charged battery is at 12.93 volts,
You haven't killed the surface charge from the charger. It's not going to be that high. Reread my most way up there.
Old Jul 18, 2023 | 06:57 PM
mikey95hd's Avatar
mikey95hd
Once I get everything back together, I'll connect the battery back up and turning on the switch, makes the light come on. So turning it on then off should be sufficient, correct?
Old Jul 18, 2023 | 07:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I wouldn`t leave the outer primary cover off...
Install with a few bolts snug, no lube to test.
Old Jul 18, 2023 | 07:40 PM
mikey95hd's Avatar
mikey95hd
I think I figured it out, I bought a newer primary, chain, compensator, and clutch, from a 2003, I put that clutch in since it came off a 2003 Softail. If you look at the picture they aren't the same.
Old Jul 18, 2023 | 08:38 PM
Jackie Paper
Yes to kill surface charge. Cranking it and voltage check gives you a crude ballpark on CCA reserve in battery.
That one on right looks like the one out of my 04. Will it even fit behind cover?
Old Jul 18, 2023 | 09:03 PM
mikey95hd's Avatar
mikey95hd
It did fit but with very little clearance on the outer primary, and I couldn't get a good adjustment, put it in gear and pull the clutch in the engine would turn over then break free and roll. Just didn't seem right to me, so I decided to compare the two, big difference between the two. As you can see in the picture.
Old Jul 18, 2023 | 10:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Is the tooth count the same on both ring gears?
Old Jul 18, 2023 | 10:30 PM
Jackie Paper
Little clearance in my 04. I made a little bent wire to spin on mouth of cover to check oil. Hard to see it.
When they act like you described, most newbies fail to find no pay before back off. See one a week on here.
Old Jul 18, 2023 | 10:35 PM
mikey95hd's Avatar
mikey95hd
Haven't counted the teeth yet, but the height of the 2003 clutch is about a inch taller, compared to the 95. The ring gear sits at a different height then the original with jackshaft engagement. So I will put the original back in since there is no issues with it prior to disassemble.
