Firing on one cylinder
Old Jul 26, 2023 | 10:49 PM
Foxb2022's Avatar
Foxb2022
Stage II
Default Firing on one cylinder
I have an 06 heritage softail. It’s only firing on. One cylinder and can’t figure out why. Tried new coil and new wires, no change. Tried putting in a new ECM and check engine light comes on and fuel pump won’t run.
now the reason I changed the ECM in the first place was because i hit a bump kind of hard and felt something rub my rear tire, thought i bottomed out, come to find out the Ecm fell through the fender and the tire rubbed a hole in it and some moisture got into it. I was told my bike might be old enough that I wouldn’t have needed to take the bike the the dealer to get reprogrammed but now thinking I might have too.
I would much appreciate any help at all thank you!
Old Jul 27, 2023 | 08:21 PM
IBE's Avatar
IBE
did you change the spark plugs?? or swap them just to see?
Old Jul 28, 2023 | 07:51 AM
Foxb2022's Avatar
Foxb2022
Stage II
yes I did. Have Twice now.
Old Jul 29, 2023 | 06:10 PM
IBE's Avatar
IBE
quit throwing parts at it and take it to a dealer, or indy.
Old Jul 29, 2023 | 09:28 PM
hattitude's Avatar
hattitude
It's possible that during the ECM incident, a connector, wire, or connector pin in the ECM area, that controls the spark, could have been damaged.
You will most likely need an HD Factory Electrical Diagnostic Manual to get the info you need, #99498-06
https://www.ebay.com/itm/18557578448...hoCAycQAvD_BwE
T​​​​​hen, if you have the skills, get a multi-meeter and check the wires and connectors. The diagnostic manual will most likely have a flow chart to follow for trouble shooting your issue..
Good luck and report back what you find..
blrobbins3
Sep 9, 2015 10:33 AM
rebar490
May 4, 2013 06:44 PM
louisg
Jul 24, 2012 06:11 PM
2007heritage
Electrical/Lighting/Alarm
Feb 16, 2012 06:44 AM
Papa Georgio
Feb 6, 2012 12:23 AM
