2012 softail deluxe
Old Aug 9, 2023 | 09:45 PM
idomoms32's Avatar
idomoms32
Stage III
Default 2012 softail deluxe
Bike will turn on, start up and shut right off, i did removed the bcm but installed it again, it has been sitting in my garage for a month. Any ideas?? Also its giving codes P1009 and U0121
Old Aug 10, 2023 | 04:10 PM
hattitude's Avatar
hattitude
P1009 - VTD Disabled fuel due to Incorrect Password
U0121 - Lost comm with ABS
Based on those codes, the second one won't cause the bike to stop running, but the first one will.
The P1009 code is usually when the ECM & BCM have not been "married", and thus cannot talk to each other. I wouldn't think just removing and reinstalling the SAME BCM would cause this...
But your DTC code says "Incorrect Password", so I gotta ask....
Did you reinstall the same BCM that you took out...??
If you did, I would disconnect the battery, let it sit for an hour or two (doesn't actually take that long, but I always err on the side of caution). During that time you should check the connections for proper contact, good pins, no corrosion, etc., etc.. Then reconnect the battery and see of the BCM & ECM will start talking again...
If they don't start talking after that reset, or you may have to go through the process of "marrying" the two modules again...
Obvioulsy, if you installed a different BCM, it won't run until you "marry" that BCM to your ECM..
I hope that helps..
NOTE:
I just read this thread on search, it may help... https://www.hdforums.com/forum/harle...ery-p1009.html
Seems in this thread the guy reset the security by pulling the security fuse while the ignition was on. Worth a try if the basic battery disconnect reset doesn't work...
ptrus
Mar 17, 2023 02:55 PM
tattooedpapa
13
Feb 27, 2023 08:03 AM
matte
Sep 13, 2021 05:39 PM
Chinwig
Sep 24, 2016 05:31 PM
Aquam
Electrical/Lighting/Alarm
Jun 15, 2016 04:38 PM
