Another "Oil in throttlebody & oil usage" thread
Old Sep 21, 2023 | 12:39 PM
wztravis's Avatar
wztravis
Default Another "Oil in throttlebody & oil usage" thread
Beating a dead horse here. I've been watching my oil usage on my all stock (minus slip ons) 2019 107 FLHC. It's pretty exorbitant. I have to check the oil after each ride and keep a close eye on it. Never have I had to top off such a new vehicle. Bought the bike this year with 3000 on it from the original owner who babied it. It now has 9000. What I've noticed is that there is a lot of oil inside the throttle body and I can smell it being burnt as I ride. I've been running Amsoil 20w 50. I'm thinking of switching to a conventional (Valvoline) 20w50 to see if that slows the usage down. Aside from the excessive oil usage and the stupid kick stand, I love the bike. I've read that the rocker box breathers could be at fault causing excessive blow by and that Fueling cylinder head breathers could be the solution. They are $$$$ but if it could solve my issue, I'm fine with spending the money. It just seems like a crap-shoot. I run just over 4 quarts in the bike at oil change, and the level never gets past the half mark regardless of what check method I use. Typically, it's just touching the stick because any more oil than that automagically disappears anyhow. I'm aware of the 1qt per 1k miles tolerance, which is hogwash. This was a ton of money for a bike that burns that much oil. Any other recommendations to slow the oil consumption? I dig the scooter but am now pretty leary of it's ability to last.
Old Sep 21, 2023 | 12:59 PM
RANGER73's Avatar
RANGER73
I've read here that The brainiacs at the mother ship of Harley Davidson have recently put out a service advisory NOT to use Amsoil.
Old Sep 21, 2023 | 01:30 PM
eighteight's Avatar
eighteight
How much oil is used in how many miles ?
Old Sep 21, 2023 | 01:50 PM
bustergut's Avatar
bustergut
This forum may be more appropriate to your model:
M8 Softail MY2018-2023 2018+ Softail Models - Harley Davidson Forums (hdforums.com)
Old Sep 21, 2023 | 02:28 PM
wztravis's Avatar
wztravis
I seem to be using a quart every 1200 miles or so. To me that's pretty nuts for a 20+k machine. If I run the interstate it uses oil even more quickly.
Old Sep 21, 2023 | 04:07 PM
strych9's Avatar
strych9
I think Harley's threshold (someone please confirm) is 1qt per 800 miles. Anything above 800 miles is normal. HD won't even look for a cause in that case. Oil in the TB is normal for these bikes. If it were burning through the exhaust, I would think you'd see a bit of bluish smoke.
Old Sep 21, 2023 | 08:10 PM
Bone Doc's Avatar
Bone Doc
If you stop adding oil, eventually it will stop burning it. Sorry, no help.
Old Sep 21, 2023 | 08:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Good grief... It was a baseless third hand story.
Old Sep 22, 2023 | 02:35 AM
04FXDI's Avatar
04FXDI
Right on que, you don't miss an opportunity to provide the same response to practically every post here. Can't you provide real content and information?
Stop padding your post count.
Old Sep 22, 2023 | 03:37 AM
eighteight's Avatar
eighteight
Originally Posted by strych9
I , I would think you'd see a bit of bluish smoke.
At the least speckles on the plugs or soot in the tail pipes.
