Parasitic battery draw
Old Sep 30, 2023 | 12:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The first thing you need to do is charge the battery and take it to an auto parts store and have them load test it.
Until you have a known good battery, fully charged, attempting to troubleshoot is just chasing your tail.
.8 amps?
Are you sure it is not .8 Milliamps?
Old Sep 30, 2023 | 03:14 PM
Kenomni's Avatar
Kenomni
It took all day to charge up this fairly new battery. My meter was set to the 10 amp DC scale and it read point 8 amps. I was afraid to set it to milli amps as my meter only reads that scale up to 200 milli amps. Plus the fact that the battery was virtually dead the next day leads me to believe that it is in fact a huge parasitic draw.
Old Sep 30, 2023 | 03:18 PM
NorthWestern's Avatar
NorthWestern
Sounds like you did it right, and yes, nearly an amp of off-key draw is a battery smoker.
Even on a group 31 battery, 8 tenths of an amp would drain it overnight to the point a vehicle would not start.
Old Sep 30, 2023 | 03:31 PM
im's Avatar
im
Does your bike have security with a siren?
Old Sep 30, 2023 | 04:14 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Just a thought, if the battery is fully charged and disconnected does it hold a charge?
Would not be the first time a newer battery had an issue with plates having a parasitic draw.
Old Sep 30, 2023 | 05:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Make sure it is not a bad battery, charge it and have it load tested.
Don`t speculate, troubleshoot.
Old Sep 30, 2023 | 06:12 PM
YZR's Avatar
YZR
OP, listen to this guy, he knows his stuff.
Old Sep 30, 2023 | 08:46 PM
RANGER73's Avatar
RANGER73
And do it before Rounders shows up.
Old Sep 30, 2023 | 08:57 PM
QC's Avatar
QC
Old Sep 30, 2023 | 10:41 PM
Kenomni's Avatar
Kenomni
The battery stayed fully charged overnight, although it had been disconnected from the battery cables. Still in the process of disconnecting harnesses individually. I removed the fuel tank and then when I disconnected the IAC connector the parasitic draw went from .8 amps to .38 amps. Could this be my smoking gun?? I know that this draw still seems a bit high but I also noticed that when I turn the meter on, the anti-skid solenoid energizes and I'm thinking this is normal and drawing that .38 amps.
