How do I properly remove this screw?
On bolts, the terms "really high quality" etc are not very accurate. You probably want grade 5. Grade 8 are stronger but less ductile. Then you can get into AN bolts.. You need to be a bit more specific.
Grading of fasteners and usage is a whole larger discussion.
Yes, bolt grades are a very technical topic on their own. I know very little about the specifics. I just know that I don't want bolts that will shear very easily under load, nor do I want them to be so strong they transfer too much force to the frame. Your recommendation of grade 5 is appreciated!
Jim G
"Oh, and I love how you called that x-mas tree plug a "plug worth pennies"....
While you are most likely correct on its cost/value.... that part is #10040 Xmas-Tree Clip @ $2.13 each, from your dealer.....
Luckily, you can get a 146 piece assortment of those clips for $9.89 from Amazon.... but then your bike will no longer be OEM...
I wonder if an aftermarket clip would void your warranty..
"I intended them to be amusing, I wasn't making a serious commentary on warranty requirements or the quality of HD supplied parts...
I often crack myself up, yet others don't think I'm as funny as I do...
Jim G
The instructions show the service part numbers.
According to HD's hardware list, the top screw (856A) is Grade 8.
The hardware list doesn't specify the grade for the bottom screws (4188).
https://www.harborfreight.com/panel-...ers-63699.html
In using the, I find they either work perfect, or not at all. I've never had an in between. Either it pulls the clip out as it should, or it rips the plastic head off.
If it works, great. If it rips the head off? Well, long as you've got access to the backside of the hole, popping it out with a dowel is still an option. Only now, without the head you can do it from either side.
The top bolt is very different. Up there, the bar will try to shift SIDEWAYS when it hits the ground. There is NO frame material that it can push into. It will instead try to SLIDE SIDEWAYS away from the impact. That means that the top bolt has to be able to absorb the entire top impact by itself, and it will experience an almost purely SHEAR force, not a compression force. THAT's why that bolt needs to be much stronger, and apparently needs a Grade 8 rating. So, I will buy a Grade 8 bolt to replace the top bolt in the aftermarket engine guard.
Thanks for taking the time to look this up. I really appreciate it.
Jim G
I'll bet the designer who specified the use of these pkugs in those 2 locations did not stop to think about how hard they might be to remove on a fully assembled motorcycle versus a bare frame!
Jim G
Jim G
A grade 5 button head torx screw will have 3 equally spaced lines embossed in the head. A grade 8 will have 6 lines.
Below is an image of a HD grade 8 button head torx screw. Because the angle of the pic isn't head on, only 4 of the 6 equally spaced lines are visible.
Jim G
